Question about Chase 18.5mm-29.5mm PRECISION ROLEX OYSTER CASE OPENER Watch
My watch stops 1-2 minutes after setting it. I pull out the knob and the second hand stops. I set the time and push the knob back in. The watch starts to tick as it is supposed to but it stops shortly after.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Sounds like your Rolex needs a reular serviceing, Check with the Repair Service Directory here at fixya, bottom of this page click on Reapir Service Directory, then watches, choose a repair service that specializes in Rolex watches.
Posted on Jul 10, 2010
How do I set the time and date on Kenneth Cole women digital watch with 1 knob. Model KC2698. Thank you
most watches with one knob have a duel action on that knob
the first click is the date section , pull it out a bit further to a second click and that is the hands movement
when set to right date and time push the knob all the way back in
Mar 11, 2016 | Kenneth Cole Watches
How to use the alarm in seiko snaa30
pull the knob into the second position. push the lower button to set the alarm dial in 1-minute increments. hold button to speed up the proces.
When ready, pull the knob back in the default position.
To reset alarmtime: pull the knob beyond the second position (click). You an feel your pulling against a spring and the indicators will advance to the current time again. (if it was set as the current time).
Mar 06, 2014 | Seiko Mens Snaa30 Alarm Chronograph Black...
Dont know hoe to set the coreect time and date
Thank you for contacting FixYa.
ANALOG
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
  • Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
  • Best regards. Jewel
    Sep 13, 2010 | Watches
    How do you set the day of the week?
    Since you didnt tell me what KIND of watch it is I am giving you a general instructions.
  • Wait until the second hand is at zero (the top of the dial). Then pull the crown knob out as far as it will go to set the time on your watch. Turn the knob in either direction and look at the three additional hands on the time dials of your watch: the minute hand, the hour hand and the 24-hour hand.
  • Step 2 Stop turning the knob when all minute and hour hands are pointing to the correct time. Pay special attention to the 24-hour hand so that you have a.m. or p.m. correct.
  • Step 3 Push the knob back in exactly when a new minute is starting so that your second hand will be correct. Use another clock you know to be accurate as a reference, such as the government clock available online.
  • Step 4 Pull the knob out halfway so you can set the date. Turn it counterclockwise until you notice the date on the watch changing. Stop it and push the knob back in to its starting position once you reach the correct one. Try to set the date before 9 p.m. If you set it after that time, it may not register with your watch that it should switch the date at midnight. If this happens with your watch, just fix it the next day.
  • Step 5 Set the chronograph, or big dial, on your watch. It works like a stopwatch to let you time activities for up to one hour. Push the top button on the side of your watch to start it. Push it again to stop it. Push the bottom button on the side of your watch to reset it.
  • It would certainly help if next time you let us know what kind of watch it is you have, Best of luck.
    Aug 11, 2010 | Watches
    Setting a cartier chronograph watch
    1. click the top button to stop the second hand
    2. click the bottom button to reset the timer
    3. pull the crown out all the way
    4. twist the crown forward hard and fast for a few seconds. The minute hand will start advancing very quickly.
    5. when the desired date and time is reached, push the crown back in place. If you missed the time, pull the crown back out and twist backwards. The minute hand will move slowly in reverse. If you twist hard and fast, the minute hand will start spinning in reverse again.
    Sep 15, 2009 | Cartier Tank Francaise Chronograph White...
    I need to reset the hands
    Assuming you want to reset the zero posistion of the chronometer (stop watch) hands...
    On my watch I can adjust it by doing the following...
    To reset the microseconds hand / top right
    1) Pull the center knob full out (2 clicks)
    2) Press the bottom push button to adjust the hand
    To reset the seconds hand / middle
    1) Pull the center knob a full out (2 clicks)
    2) Press the top push button to adjust the hand
    To reset the minutes hand / top left
    1) Pull the center knob out half way (1 click)
    2) Next press the bottom push button to adjust the hand.
    Once all hands are reset, push the center knob back in fully...done
    Mar 16, 2009 | Swatch Irony watch
    Need instructions on National Geographic Men's watch #NG010GYSK
    go to Buliva web site and look for the chorograph 561/598
    FEATURES
    1. Hours, minutes, seconds and date display.
    2. 60 minute Chronograph (CHRONO) with minutes and
    seconds display.
    3. 24 hour hand, permanently synchronized with the normal
    12 hour hand.
    A. SETTING THE TIME
    1. Pull the crown out to position “3” (See diagram). If the crown has
    a “screw-down” lock, then unscrew the crown lock first by turning
    the crown toward you, then pull it to position “3”. Do not forget to
    screw the crown back “IN” after all setting is completed.
    2. Turn the crown towards you (hands moves clockwise) until the
    date changes at approximately midnight.
    3. Continue turning the hour and minute hands to the correct time.
    If it is afternoon you must go past 12 o’clock again (noon) to set
    the correct time.
    4. When the correct time is set,push crown back to position “1”.
    B. SETTING THE DATE
    1. Pull crown to position “2”(See proceeding diagram).The watch
    will continue to run.
    2. Turn the crown away from you until the correct date appears.
    3. Once the date is set, push the crown back to position “1”.
    Note: Do NOT set the date between the hours of 8:00 PM and
    3:00 AM.This would not damage the watch,but the date may need
    to be reset later.
    C. CHRONOGRAPH (CHRONO) ADJUSTMENT
    If the chrongraph second hand is not positioned at the proper
    starting position (12 o’clock or “zero” position), use the below
    procedure.It does not need to be repeated unless the watch
    receives an impact sufficient to move the hand out of position, or
    the Battery has been changed.
    1. Pull crown out to position “3”.
    2. Push button “A” to move the Chrono Second hand (long hand) to
    the “0” or 12 o’clock position. Each button push will move the
    hand one step – BUT holding the button down will advance the
    hand rapidly.
    3. Push crown back to position “1”.
    D. USING THE CHRONOGRAPH (CHRONO)
    Note:
    The maximum chrono reading is 60 minutes, However the
    chrono will continue running once 60 minutes has passed. The
    resulting one hour periods may be added together mentally to keep
    track of longer periods.
    For example – If you know that approximately one hour has
    passed since you started the chronograph, and the chrono reads
    25 minutes, then you know that the chrono has been running 60
    minutes plus 25 minutes, which is one hour and 25 minutes.
    1. Push Button “A” to start the chronograph. Push button “A” again
    to stop the chronograph.
    2. Push button “B” to return the two chronograph hands to the
    “Zero” or starting point.
    3. The Chronograph can be stopped and started again
    (Button “A”), repeatedly, to “ADD” times together.
    BOOK NO. 561/598 Chrono FS00/01/10
    Watch Setting Guide
    4/2007
    Feb 13, 2009 | Bulova Watch
    How do you set and deactivate the alarm function.
    I did find two authorized dealers:
    www.kenmarwatches.com
    www.princetownwatches.com
    Contact both and request users manual fur your specific model. They must be able to help.
    Jan 05, 2009 | Bulova Watch
    I have a seiko flight watch, unknown of the model, second hand doesn't reset
    I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
    All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
    Hope this helps,
    Krishna Chaitanya GT.
    Apr 27, 2008 | Seiko 0512039FA Wrist Watch
    How to Set Alarm
    This is the movement used in the following Seiko watches..
    SNAC74 SNAC75 SNA548 SNA694 SNAC40
    SNAC41 SNAC42 SNA749 SNAC03 SNA411
    SNA414 SNA765 SNAA03 SNAA05 SNAA01
    SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
    SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
    SNAA61 SNAC38 SNA283 SNA695 SNAA30
    HOW TO SET ALARM TIME
    1. Pull the crown out to the second click position.
    2. Press button “B” to set the alarm hour and minute hands to
    current time.
    3. Push the crown back to normal position.
    4. Pull the crown to the first click position.
    5. Press button “B” to set the alarm hour and minute hands to
    desired alarm time.
    6. Push the crown back to normal position.
    Note:
    Alarm setting on a 12-hour basis only. Alarm will ring at the
    designated time for 20 seconds; one time alarm only. The alarm
    needs to be reset in order to re-engage the alarm function.
    HOW TO USE CHRONOGRAPH
    1. Set crown at normal position.
    2. Press button “A” to Start/Stop/Restart.
    3. Press button “B” to Split/Split release/Reset.
    HOW TO USE ALARM DIAL
    AS DUAL TIME DISPLAY
    2. Pres the button “B” to set the hour and minute hands to time of
    a different time zone.
    Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
    Chase 18.5mm-29.5mm PRECISION ROLEX OYSTER CASE OPENER Watch Logo
    228 people viewed this question
    Top Chase Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Chase Watch Expert? Answer questions, earn points and help others
