Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Kenmore fridge very warm .tried cleaning under also unplugged for 18 hours
  • Kenmore Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorkenmore fridge very warm - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
My Kenmore side by side freezer and fridge sides are warming.
your ptc overload/relay on the compressors bad,unplug the unit and remove this ptc part off the compressor and replace it
May 02, 2012 | Kenmore Side by Side Refrigerator
Fridge is not keeping the food cold, water at the bottom of fridge, freezer is not as cold, still freezes things but takes a long time. This is a Kenmore 20 fridge, my guess is 15 years old.
unplug the fridge and leave the doors open for 48 hours, then see if your problem is gone 24 hours later after you plug it back in, if it is, your fridge needs to have a repair to the defrost side of things, most likely the defrost termination therm or the defrost timer, also make sure the drain under the evaporator is not plugged up
Jul 22, 2011 | Kenmore 20.6 cu. ft. Top Freezer...
KENMORE REFRIGATOR FREEZER THE FREEZER WORKS FINE THE REFRIGATOR IS WARM
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore refrigerator Freezer is cold but fresh food side is warm
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Jan 26, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore upright fridge--freezer door drips when cleaning
Condensation has formed and frozen behing the door panel. You can live with it, or take apart the panel and dry it out - you may have to replace some insulation. Hope this helps!
Feb 07, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
The partition between fridge and freezer is boiling hot
some of the hot pipework is routed across the transom between fridge and freezer to prevent condensation.. this will be hotter when you start up a warm appliance.
temp can not go so high as to cause a smell of burning so look elsewhere for that - maybe the compressor electrics
Oct 12, 2008 | Frigidaire FRT15B3A Top Freezer...
Kenmore 795.7731 Fridge warm;freezer cold - Error er dH
I faced the same problem for Kenmore elite Trio Model # 795.77543600 bottom freezer refrigerator. The issue as pointed out by Medeer on fixya.com, turned out to be the part called component assembly, part number 6615JB2005H. I got this replaced yesterday but for 4 hours I did not notice any cooling... so I thought it did not work.... but then in the morning I notice that the issue has been resolved, the refrigerator is cold and there is no eR dH error message. Thanks to all who shared on this site.
Feb 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore refridgerator c1065094881
It sounds like your defrost cycle has stopped working. unplug your fridge for 24 hours and let it defrost. plug it back after 24 hour and if it starts to cool in the fridge part at about 40 degrees F. you will have to replace one of three parts the Defrost Timer, Defrost Themo or Defrost Element. I hope this helps you.
Dec 22, 2007 | Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
