Question about HP DeskJet F380 All-In-One Printer
HP DESKJET 3820 PRINTER POWER SUPPLY BURNT RESISTOR
My printer's power supply failed and I found a shorted FET, open resistor, open 1N4148 diode and a sm resistor on the solder side of the PCB burnt beyond recognition. Does any one knows its value. It is right under the filter cap C5: There are 3 105R, 2 334R, 1 124R and one missing. The PSU is an ASTEC model AA20550, PART # C6426-60081.
Please help it is my only printer and i need it.
ginko
  • 19396 Answers
SOURCE: HP Deskjet 3820
Tray this link: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=75045&cc=us&lc=en&dlc=en&product=75045&dlc=en&lang=en
cheers
Posted on Feb 14, 2008
IB4G2008
  • 3587 Answers
SOURCE: HP Deskjet 3820 states system error
try disconnecting from computer, and run the test page from the panel..then, reconnect to computer and see if it repeats..sounds like the operating system may have lost the printer drivers..
Posted on Mar 07, 2008
antiochpc
  • 1314 Answers
SOURCE: hp deskjet 3325 not installing
You need to download the appropriate driver or follow the instructions for your operating system.
HP Deskjet 3325 for Vista
HP Deskjet 3325 for XP
Posted on Jun 23, 2008
Bubbabear64
  • 2794 Answers
SOURCE: hp deskjet 3820
Take the cartridge out and clean it with a qtip and reinstall it.
Posted on Jul 06, 2008
the ink cartridges get stuck on the right side. The is a square white looks as if a resting area. I don't know how to fix it.
Posted on Aug 19, 2008
My kdl-32l5000 has a diode shorted in the power supply but i cant find out what kind of diode it is the location number is ''D6103''
Look for another diode on that circuit board that looks identical and take a reading in ohms with no meter and that the diode you will need to replace the resistor it should say on the circuit panel look with a magnifying glass
Aug 16, 2014 | Televison & Video
My laser jet printer 1018 was not picking up papers. After some time it started showing a red led after receiving a signal from the computer. trying to command it many times it failed completely, no power...
press the power button once it one for a couple of seconds and wait til your printer respond, once it respond it will print a list of the transaction on the printer. Hope it helps thanks.
Sep 15, 2011 | HP LaserJet 1018 Printer
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Aug 26, 2011 | Polaroid FLM-3232 Television
I'm trying to get my hp deskjet 3820 driver working the computer said the new hardware is in working order but cant print anything, please help
dear uninstall driver unplug printer ........
restart system install driver
and after restart plug your printer ...
but many setup say between setup plug in printer thn plug in ok.....
enjoy it ....
Dec 06, 2009 | HP DeskJet 3820 InkJet Printer
Dead Set after power surge
Check the power supply transformer primary driver transistor and the associated components (some diodes and capacitors, resistors, an optocoupler maybe) and the rectifier diodes (or a bridge) and capacitors at the transformer secondary, what you are looking for is a short circuit, however, the short may as well be in another section of the circuit board (a shorted component may sometimes have signs of damage caused by heat, but this is not a rule).
Hope you can find out what it is...
regards
Triarcuate
Oct 01, 2009 | Televison & Video
Need to find a power chord for hp printer 1610 series
Check the coltage and amperage of the power supply. You can then purchase a similar power supply with the same ratings.
Sep 08, 2009 | Apple HP DeskJet 3820 InkJet Printer
TV won't turn onthe red light just blinks when I push the power button.
I think this might be bad/swollen capacitors, or something odd in the +5VDC circuits of the power supply, but I am posting all of the things I have found so far with these TVs.
Here are few possible solutions:
If you have no red light and you have a Megmeet MLT386 power supply, check these parts:
1) Swollen caps on the secondary circuit (may cause the red light blink problem).
2) Blown fuse F1 (5A/250V) this is caused by a shorted FET at QA1 (20N60), you may also find that SMT cap CX23 is burned up (.001uf) which is in parallel with diode DA2 which may be damaged/shorted, replace these components.
If the power LED goes from red to green when powered up but no picture, then it might be lost +24VDC from the power supply:
3)Check fuse F2 (3.15A/250V, I put a 5A in), if it is blown, replace FET at QA2A (9N50C), replace QA2 as well (9N50C). Check SMT resistors at R233,R234,R235,R236 (.47 ohm). If open, replace with .1 ohm 1W or 2W resistor (easier to source). Also replace SMT transistor QF1 (2X4 or 2N4401 NPN transistor). And replace diodes at DS2 and DS1 (HER207), DS2 was shorted, DS1 was ok but I replaced it anyway.
I dont know as much about the Megmeet MLT169A, but it has similar problems and similar components.
4) I had to replace all of the capacitors in the secondary circuit (there are six in a 3x3 row marked EC9 (1000uf35V),EC10(1000uf35V),EC14(470uf35V) and EC18,EC19,EC20 (all 1000uf35V).
Aug 10, 2009 | Akai LCT3201TD 32 in. LCD Television
Rockford Fosgate 200S amp, not powering up, some burnt components found.
If the resistors go to the gates of the power supply FETs, the FETs are probably shorted. Measure the resistance between the gate and the drain (no power applied to the amp). It should be at least several thousand ohms.
If you can take high res photos, send them to my email address:
babin_perry@yahoo.com
Dec 21, 2007 | Car Audio & Video
HP Deskjet 3820 Printer
If you love it (3820) better learn how to clean the service station or it will shear the gears and be done.
See my post under the blinking light problem with 3820s.
I really like the printer and wish someone had told me this before mine broke. No answer for your question, but HP.com should have manuals as a pdf download.
Dec 12, 2007 | HP DeskJet 3820 InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
218 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
