Question about Amana ABB2224D Bottom Freezer Refrigerator
Leaking water Water leaking from somewhere? Icemaker? Not water line. Any suggestions?
  • Amana Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jul 13, 2010
We have a Samsung side by side. Ice maker on the top as part of frig. water is leaking and I see the ice stopper is not closing to keep the warm air from entering the ice compartment. Any ideas
If the icemaker is leaking water onto the floor:
  • Turn off the icemaker and then turn off the water supply to the icemaker. See Icemaker On/Off Switch.
  • The water supply line is usually located under the kitchen sink.
  • Locate the cold water line and look for a small 1/4" copper line attached to it. Where these two lines meet, there will be a saddle valve. This is the shut-off valve. Turn this valve in a clockwise manner until it stops. This will shut off the water to the icemaker.
Aug 11, 2017 | Samsung Refrigerators
Why does my ET1CHEXVT01 refrigerator leak water on floor
Check the icemaker connections at the rear of the fridge. Be careful with the 1/4 " supply hose when moving the fridge. Plastic lines sometimes become brittle with age.
Dec 27, 2014 | Refrigerators
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
ICE MAKER NOT MAKING ICE AND THE WATER IS LEAKING INTO THE BOWL
if water was leaking consistently then you would have an issue with the water valve in the rear of the machine whereas if it were overfilling the icemaker ice tray this would be a seperate issue with your icemaker and you would have to replace the icemaker best thing to do is turn off the water line that comes in from the rear of the machine There are no repairs for the icemaker that I would suggest seeing how it would cost you 4 times as much to do a repair to an icemaker rather then just buying a new one if you have any further questions message me back and please remember to rank how this opinion has helped when our chat has fully concluded it allows me to help others in similar situations in the future Thanks again Rick
Apr 28, 2011 | Frigidaire FRS23R4A Side by Side...
Maytag fridge no water to icemaker any suggestions
Pour about 2/3 cup of water into ice maker . If it freezes and dumps , replace the water valve . If it does not dump , replace the icemaker . Also make sure the coils are clean beneath refrig , and the clear fill tube , which fills the icemaker , is clear of ice (not frozen up ).
Sep 12, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker frozen, water leaks from bottom of refrigerator
I am assuming this is a refrigerator that has been in use for some time. The water line coming in is connected to a solenoid valve, this is activated when the icemaker cycling sends a signal for more water. There should be a downward tilt so the water drains from the inlet to prevent freezing of the line. If it is leaking low in the back where the water connects it may be that your solenoid valve is leaking and that you are not getting good water flow to the icemaker. Meaning two things no or very little ice and the possiblility of freezing.
Unless you know what a solenoid valve is and I suggest you call a repair man.
May 03, 2009 | GE Refrigerators
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
The icemaker leaks water from the fill tube into the fridge
my suggestion is to start from the beginning! shut down the fridge for a couple of days store food somewhere else (obviously and see if you get much water at bottom. have mos and bucket nearby. blow into any hoses that are accessible. unplug fridge of course.
Mar 18, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Leaky Refrigerator
remove the whole back cover at the bottom and check all the nylon lines. they get britle and crack from the heat that the compresor and condesor make. chack that and get back to me. I may be able to send a parts break down / explosion if I can get the model number.
Cheers,
Todd
Oct 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking inside freezer ice maker
sounds like the line was frozen but the water fill indicator is faulty.
Jun 05, 2007 | Hotpoint HSS25GFP Side by Side...
Amana ABB2224D Bottom Freezer Refrigerator Logo
54 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
