Question about Sharp Televison & Video
We have a sharp LC 46HDTV the volume needs to be on loud to hear it.
  • cmg1853 Jul 10, 2010
    very helpful
  • Sharp Master
  • 6,993 Answers
is the TV connected to a cable box or DVD player? If yes, check the volume control on your cable box or dvd player and make sure the volume is at maximum.
If this does not solve the problem, please state in details how the problem began and what you connected to your TV.
Bye for now
Posted on Jul 10, 2010
The volume on my sharp--lc19SB25U is barely loud enough to hear. I have other tvs and don't have a problem hearing them. can this problem be solved.
Tries tv unplug,replug it back like about an hour later to let the tv resetting itself back to the factory setting.Go into Menu go to AUDIO Setting go down to reset back to the original setting.If this dosen't help the whole tv Tuner signal board is the causes and the problems.Tries websites like Shopjimmy.com,Ebay.com to buy a whloe refurbish tv Tuner signal board for the replacement.
Dec 17, 2010 | Sharp LC-19SB25U 19 in. LCD HDTV
I have a sharp 32" bought at Walmarts at the Christmas before last and the low volume is driving me nuts. In my small living room with Volume set at 60 it still is not loud. Is there a trick to get louder...
Unfortunately it seems to be a sharp thing. I have a sharp 46 inch and there are times when I find it difficult to hear. Some channels seem to work fine with the volume right around 20 - 25. Seems to be quite often though that my volume is set over 40 and still struggling to hear. Seems with my tv that there is no difference between it being set on 35 and 60. They sound the same. Surround sound is the way to go if you stick with sharp.
Jul 10, 2010 | Sharp LC-26D6U 26 in. LCD Television
Have a sharp aquos TV. Cannot get the volume very
If you have the tv signal coming from the cable box, then check the settings for your cable box. if not check your owners manual.
Feb 08, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Can you hook something up to the aquos to get louder volume?
ARE YOU HOOKED UP TO A CABLE BOX? IF SO THERE IS A VOLUME ADJUSTMENT ON THE CABLE BOX TO HELP OUT. IF NOT I'M AFRAID YOUR ONLY SOLUTION IS TO HOOK UP A SURROUND SOUND SYSTEM.
Feb 03, 2009 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Volume not loud enough
are you watching movies frm a dvd player with the sound up, if so, turn the sound up on the dvd player remote and see hwo that works. eor, if its movies on normal tv screen, go to settings and click booster sound too hear better. if yours does not have this, ring your manufacture for a refunded tv with better speakr sound quality.
Oct 01, 2008 | Sharp Aquos LC-32D40U Television
Maximum volume on the set is too low!
On some cable boxes they have their own volume control. Raise the volume on the box if you can. if the volume on the tv is up all the way it should be loud. It should not be the tv if you have volume already coming out. try hooking up a dvd player or some other device and see if you have the same result
Aug 06, 2008 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Sharp LC-42D43U troubleshooting with the maximum volume sound
Found this on another site and it worked, had to switch back and forth a few times but it worked........
I have a Sharp LC-46D43U LCD TV. I think this is a entry level for large lcd tv's. With the volume all the way up at 60, my wife and I could barley hear the tv. I was playing around in the menu and some how have the volume at almost twice the volume. What I did was:
Go into the menu
Go to option
Go to output select
and change from fixed to variable and back to fixed. You may have to do this a few times.
Sometimes the volume goes loud after 1 try and sometimes it may take 10 or 20 tries.
But if I change any settings, even the channel sometimes the sound goes back down to where it was.
Has anyone done this, did it work for you. I don't know very much about electronics and I have now ideal why this happens.
I wonder if this is just something with my tv.
Mar 03, 2008 | Sharp LC-42D43U 42 in. LCD HDTV
LC-52D43U Volume Problem
if connected to a cable box is that vol up .
and is the vol up on the tv at the same time, 2 remotes 2 volumes
the other is that you may have changed the settings in the menu for surround / 3d or such and each effects max sound .
Mar 02, 2008 | Sharp LC-52D43U 52 in. LCD HDTV
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Open Questions:
Did I install the t-con board wrong? I was having flickering on my sharp aquos and replaced the t-con board. Now I get no picture. After I thought the new t-con board (verified exact same part, ordered on tv parts today) was defective because I got no picture after installing it, I decided to swap back to the original t-con board. when I did that I still had no picture. Which made me think I installed it wrong. I undid the cables, reinstalled the ribbon and the menu appeared on the TV when turned back on. So that made me think something wasn't set right w/ the ribbons when I installed the new t-con board. So I swapped back to the new one, and after trying to make sure I set the ribbons correctly, I still have no picture. So then I went back to the old t-con board (because as I just verified, it was working after I re-installed it the 2nd time) and now I STILL have no picture. I swapped back and forth a couple more times and I can't get any picture to show up. So that makes me wonder did I possibly fry something (I was very careful, kept myself grounded, didn't get rough w/ the ribbons, etc) or is it something like the ribbons are just extremely sensitive and maybe they're still not set right (they're very hard to reach)? Any thoughts on how I could test the t-con boards to check if they're good and I didn't blow something? I saw a video that it's possible w/ a multimeter but I'm not sure where the fuses are on the board or which area to test. Thanks in advance.
Jan 15, 2019 | Sharp Televison & Video
Televison & Video Logo
13 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
