Question about Ducane 30400040 Stainless Steel Grill
Re: hi my kenmore elite grill seems not to heat enough what can I do.?
  • Mrplayer Aug 26, 2008
    i Have the same problem all burners lit up but not enough heat . My is 30400040 Stainless steel only 1 year old
I have this Stainless steel model same problem not enough heat
All burners are fine , and it is natural gas . Any advice greatly appreciated . Thanks in advance
Posted on Aug 26, 2008
  • 36 Answers
How old is the grill?
When was the last time you cleaned the grill?
Is it Liquid Propane or Nat. Gas?
Posted on Apr 27, 2008
Kenmore elite 110.7703 no heat
Hi there
From the model number it seems this machine was made by Whirlpool for Kenmore. The thermal fuse is on front bottom near the blower wheel.
a) Pop open the front panel.
b) Then remove front door panel by removing the two secrews
c) Remember to disengage the door switch wiring
d) you will see the thermal fuse near the blower compartment.
e) If thermal fuse is burned out then it should not have continuity on OHMS scale on a multimeter.
Dec 07, 2013 | Kenmore Dryers
Grill won't heat up over 250 degrees
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 04, 2010 | Kenmore 16228 Grill
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
My kenmore elite grill has a ceramic cooking grid. it is 1 yr old.recently a problem developed. the ceramic grid lights as usual, but does not stay lit.once i let go of the knob the burner goes out. thanks...
check thermo coupling., its purpose is to keep heat at flame area-helps keep flame lit,like a pilot light... clean it with a finger nail file LIGHTLY- or use sand paper LIGHTLY, just to clean surface..
Nov 27, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Kenmore Classic Grille model 911-469-8813 error F2
Over time I have had to replace the control module at the front of the oven. It gets baked by the oven heat, and unfortunately costs hundreds of dollars to replace. I have avoided further failures by making sure the downdraft exhaust fan is ALWAYS on when the oven is on. This seems to keep it cool enough.
Nov 18, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
One side of the grill cooks on lower temp then the other side.. tried new burners but that did not help, what can i do
close your burners up sounds like they are open to much also you make not have enough gas going to the grill, if this is your grill in the picture then you need a half inch line for it
Aug 13, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Low output
The grill is not staying lite and not heating up like it should.
Jul 03, 2008 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Grill won't heat to high enough temp.
My first kenmore had this problem from time to time. My dad bought me a new kenmore and it has the same problem of not turning onto high but stays on low. kenmore grills ****!
Jan 05, 2008 | Kenmore 17228 Grill
Kenmore Elite Grill will not start
The gas regulator that attaches to the tank may be bad.
May 18, 2007 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Ducane 30400040 Stainless Steel Grill Logo
158 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
