Question about Mitsubishi WD-57731 57" Projection HDTV
Air Flow Problem
I'm having the problem described...and your fix sounds right. Can you describe the repair or provide a step by step guide for a non TV Tech guru to try the repair. Thanks
My evaporator is icing up and the tubes coming out of the compressor are warm. Do I need gas or is the compressor shot?
First check to see if you have proper air flow through the evaporator. If the fan in the evaporator is not working it needs replaced. Often I have found the most common problem to this syptoms described is the freezer overstuffed and air flow is blocked by product. Frozen food need space between items for air to circulate and the inlet on outlet vents on the evaporator need to be unblocked.
while your at it go ahean and look at the condensing coils under your refrigerator, if you have exposed coils these need to be cleaned also. This last step has little to do with your syptoms described, but while you are messing with your refrigerator, condensing coil cleaning should be done at least every year. If you have the type of unit where the condensing coil is in the wall of the casing, then ignor this step. It does not apply to you.
Hope this helps
Dec 08, 2014 | Refrigerators
Tip
Disk read Error - how to fix
Hi there
The disk read error for the PS3 is quite common and can be fixed.
What is the Disk read error?
ok so you know when have this problem when you place your Game/dvd/blueray/cd into your ps3 and you can here it loading but nothing comes up or you get the disk read error message, Sometimes there is no loading sounds and nothing happens.
The Causes
unfortunatley there are several causes to this one,
It could be the lens that needs cleaning,
It could be the Disk Drive that needs re-aligning as described in the Yellow light of death and the red flashing light tips about the Chips inside over heating, this can cause the motherboard to arch and slightly taking the disk drive out of sync.
It could be the laser that needs re-aligning
The Solutions
Solution 1
Ok so you can send the console off to sony they will collect it, repair it and send it back, this will usually cost you $150
Solution 2
My favourite solution is the PS3 repair guide, you can fix the problem within the hour, costs are below $40 and you don't need to be technical at all.
solution 3
Buy a new PS3 console over $200 this is the last resort.
What is PS3 repair guide
Ok so this is how i learned so much about PS3 and got me into the job today of fixing PS3's
The basic PS3 repair guide: is a high quality Pictured ebook, with the most basic step by step instructions that will fix your PS3
A good PS3 repair guide: This will contain the above mentioned and will also have a website which you can get 24/7 tech suppot to help with the fix, A forum with over 60,000 user's who have been in you position and can help you. Also some have great step by step video's.
The PS3 repair guide Comparison site
Ok i want to introduce the PS3 Problems gone Website this will be pivital in helping you choose the best repair guide, to get the best head start in fixing your PS3 you need to see the best repair guides on the Web today.
Conclusion
Ok so get your ps3 fixed get back to gaming and if anything else happens to fail you have your back up with the PS3 repair guide as its your's for life.
Good luck and happy gaming
on Jun 12, 2010 | Sony Playstation 3 (PS3) Console
Will you help me fix my Frigidaire fac107p1a unit?
Good morning friend, I appreciate your post!
I understand that you are trying to diagnose and repair your Frigidaire air conditioner, FAC107P1A. Could you describe what your appliance is doing so that I can assist you better in pinpointing the problem before any additional steps are taken. I have provided the link to where you could find additional information regarding a manual for your air conditioner as you have requested as well. I look forward to assisting you. -Matt
Frigidaire Manual Search Results
Jul 23, 2014 | Frigidaire FAC107P1A Wall/Window Air...
I have a 19999 Mazda B2500. The idle is very rough and when you step on the gas pedal the engine surges between idle and about 1500 RPM. It can best be described as acting much the same as the governo
it sounds like a lambda sensor issue, the lambda sensor is located on the exhaust manifold, it controls the emisions, it also controls the air/fuel mixture to control the emisions, if it is faulty it could cause the engine to surge like you describe
Aug 02, 2012 | Mazda Cars & Trucks
How to fix my xbox 360 red lights.
Here is a step-by-step guide to fixing the red lights error on your Xbox 360:
Step One - Contact Microsoft
Without knowing the exact details of your console, when and where you purchased it, and where you live, I cannot tell you for sure if you still have a warranty on your console. However, if your console is less than 2 years old you should be in with a chance at getting it fixed or replaced under warranty.
If you live in the USA then ring 1-800-4MY-XBOX (1-800-469-9269) If you are not in the USA then visit Microsoft.com and find your local service provider (this will be available under the support section of the website)
When you get hold of Microsoft tell them that you have the red lights error on your console, and state the following:
1. Whether there are any extra error codes on your console (like the e73 or e74)
2. How long you have had your console for, when you purchased it, and from where.
3. Provide your details when requested so that you can have a return box sent to you.
When you receive the return box, package up your console (minus the hard drive, remove any disks from the drive, and don't send back your controllers either) and send it back to Microsoft. You should then receive a refurbished console that is working properly within a couple of weeks.
Important:
If your warranty has expired then Microsoft are under no legal obligation to fix your console, and they will charge you around $150 to have it fixed. If you can get it fixed for free, take this route, if not then continue to Step 2.
Step 2 - Fixing Your Xbox 360 Yourself
Now that the "red ring of death" error has entered the lexicon of all modern gamers, you have much more resources at your disposal to be able to fix it yourself. Provided you can use a screwdriver, and can confidently follow video instructions then you can fix it yourself. If not you are going to have to pay to get someone else to do it.
I would recommend that you purchase an X-Clamp repair kit which is an inexpensive way to ensure you have the parts required to perform the job safely. These are very common and are extremely effective.
The following video instructions very accurately describe and show how to use virtually any X Clamp kit:
Important:
Incorrectly using an X-Clamp repair kit could damage your console and leave you even more out of pocket. If you don't understand the above instructions 100%, or have never had any kind of "hands on" technical work before, you should seriously consider having Microsoft fix your console.
You could also consider using the heat gun method that is described in most Xbox 360 repair guides- this is less likely to work successfully and permanently (although success rates are still around 80%) However, it is much easier to do than using the X-Clamp, and therefore warrants your attention.
DO NOT attempt the "bodge job" repair known as the towel wrap trick. This may work temporarily but will result in permanent damage to your console, and could even spark an electrical fire.
By following the instructions above you will be able to fix your Xbox 360 and get rid of the red lights.
Additional links for help and reference:
Microsoft.com
Xbox 360 RROD Guide
Xbox 360 Breakdown and Repair FAQ
Jan 19, 2011 | Microsoft Xbox 360 Console
Cracked lcd screen on kodak c913, can I find replacement parts?
HI,
I did some checking and you can't repair that yourself. I found this on the net for you:
Thank you for using the Step-by-Step Solutions and Repair Tool. The problem with your product appears to be something you cannot fix yourself. We recommend that you send your product to an authorized Kodak repair center for evaluation. Warranty Coverage
The terms of your warranty are described in your User's Guide. If your product is within the warranty period specified, you must provide a proof of purchase to receive warranty coverage. If you do not provide a proof of purchase, you will be charged for the repair.
NOTE: Warranty coverage does not include products that have been dropped or exposed to liquid. If your product shows evidence of this, your warranty will be void and you will be charged for repairs.
If your product is within the warranty period, having it serviced or altered in any way by a non-authorized party will void the warranty for that repair occurrence.
I am also giving you the link to the main page for Kodak in case you want to send it to them for repair or get more information.
http://www.kodak.com/global/en/service/products/replacementParts.jhtml?camera=C913
Aug 09, 2009 | Kodak EasyShare C913 Digital Camera
How do i replace the valve cover gasket on 99 dodge avenger?
You may want to look at Auto Zone web site, the vehicle repair guide.
It described how to change the valve cover.
You could also go to the public library and check out the Auto repair section and photo copy the section with valve cover.
Also advance auto web site also have a vehicle repair guide section.
You can check it out and decide if this something you want to get involve in. It describe ever step that is involve.
Mar 10, 2009 | 1995 Dodge Avenger
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
Mitsubishi WD-57731 57" Projection HDTV Logo
29 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
