Question about Hoover U5753-900 WindTunnel Bagless Upright Vacuum
Beater bar stalls
Regardless of what height setting I use, the beater bar stalls on carpet. I checked the height adjustment mechanism and it is working.
  • mike15037 Apr 19, 2008
    I pulled it apart and it is clear. If I raise up the sweeper, the beater bars turns. If I hold the beater bar and just pull the belt around the motor, it easily slips around the beater bar. Does that mean I need a new belt?
    Thanks!
  • 328 Answers
Sounds like the belt to the bar isnt turning properly or could be clogged up with dust or need replacing.
Either way youll need to open up the sole plate and check the condition of the belt by the rolling brush bar. Also check the condition of the brush bar to see if it isn't clogged up with general dirt and hair.
Posted on Apr 19, 2008
  • Ryan S
    Ryan S Apr 19, 2008
    Well there should be more tension on the belt if it slips around the beater bar, generally any new belt will be stronger in feeling. Try a new belt and see if this works. Also check that the washer caps on the end of the rolling brush have been seated properly before putting the foot plate back on.
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Kenmore model 401.39035900 vacuum cleaner beater problems
probably need a new motor and beater bar.
Feb 20, 2013 | Vacuums
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
Can I lift the vacuum beater bar higher up? Bought new carpet and would like it to push smoother!!! Bought a shag carpet
No. The Electrolux (Aerus) uprights are auto adjusting to the height of the carpet. Make sure the brush is spinning when the vacuum is on. If it's not, this will cause difficulty in use.
Apr 06, 2011 | Electrolux Epic 3500 Vacuum
Can't get the adjustment correct after removing the beater brush - won't pick up on carpet
You say you removed the beater brush--
Is this on a power nozzle, or an upright vacuum?
Is there an adjustment that you step on, to set at various heights?
(Or like on Most Power Nozzles,-- there is one a 'new
and a 'worn setting.-- In the latter you have to open up the Power Nozzle, and reverse a brush height setting piece--- it only has 2 adjustments.)
Tell us more about your machine--
Make and model might help--
But what you have done, and what are the clues-- those will help us the most.
Mack B
Jan 11, 2011 | Vacuums
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
Hoover 5470-900 no longer contacts carpet with beater brush
your floor adjustment spring is broken there is a plastic slider and clip if it is broken the height adj will not work you should get a new vacuum because this repair can cost as much as a new vac.also this is a common problem with the hoover brand I would get a sebo or an oreck they have a great warrentty and you will more than likly never buy a other vac.
Jan 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Beater Bar Does not turn
YOU MAY HAVE A POSSIBLE BAD BELT OR THE MOTOR THAT RUNS THE BAR MAY BE BAD, THE OTHER POSSIBILITY IS THE SWITCH THAT TURNS ON THE BAR MAY BE BAD. OR A WIRE COULD HAVE COME OFF THE MOTOR. i THINK YOU DO KNOW THAT THE BEATER BAR DOES NOT RUN WHEN ON WOOD FLOORS.
Dec 03, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
I have a Miele S1721 Powerhouse upright vacuum. When the belt broke I took it into the shop (because when i tried to replace the belt, the tension was so tight I couldn't get it back together!!). When I...
Hi
The Miele uprights (S170 and upwards) with the Powerhouse title are ALL Panasonic uprights which have been at one time sold in the UK. Therefore the upright may use TWO drive belts which need to be looked at: Take off the sole plate and examine the drive belt which is around the beater bar. Check that this belt is moving easily. Then look at the fly wheel to the motor (usually to the left hand side) and check that the smaller motor belt is moving - it may be broken which is why the beater bar isn't moving and why tension is tight.
Generally NONE of the Miele Powerhouse models have a manual selector for height adjustment - they all use auto adjustment which means no manual selector. The vacuum principle means that general carpet which comes into contact with the brush creates a vacuum anyway between the brush and the floor. If the brush isn't touching the floor then its a possibility dirt or debris has managed to get between the bottom 2 rollers after the beater bar. Check behind the wheels to see that there is nothing there - most auto adjusting Powerhouse models will have a spring behind the wheel and it may have come off.
May 04, 2008 | Vacuums
Hoover U5753-900 WindTunnel Bagless Upright Vacuum Logo
189 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
