Question about Dymo LabelWriter 400 Turbo Thermal Printer
One of my Dymo Printer form feed led would not stop blinking. It would not feed the label that came withthe package. Also my mouse stops work when I install the label maker usb into my computer. Dymo labelwriter 400 Turbo Thermal Printer
5 Suggested Answers
  • 164 Answers
SOURCE: We have a Dymo Label Writer 400 Turbo Thermal
I found the drivers here:
http://www.labelvalue.com/dymo-software.php
Select the drivers and/or software you need according to your operating system.
Download the software to your desktop, and run it from there to install.
I hope this helps you! If you have any more questions, leave a comment right here.
Please leave a rating if this was helpful for you.
Posted on Mar 15, 2010
  • 14 Answers
SOURCE: Dymo labelwriter 400 Turbo -We replaced the roll
There are a few common reasons this is problem can exist.
1.) the incorrect template is used when creating the label
2.) the labels are installed incorrectly - the labels must be loaded and pushed against the left side of the printer and lid closed when printing to ensure the labels don't "wander" out of the sensor's view.
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. Use quality Dymo labels.
4.) The labels are defective - if you have another roll of the same size, try it to see if it has the samme issue.
Posted on May 06, 2010
tbreeze47
  • 3083 Answers
SOURCE: We need firmware 93176vOT or 93491vOT - - - - - -
I couldn't find any information on the firmware version numbers, but I did find a site that might be able to help:
http://global.dymo.com/enNZ/HowTo/LabelWriter_400.html
You might try to contact Dymo Support, on the same link.
Good luck, and hope this helps.
Posted on Sep 22, 2010
How to reset the dymo labelwriter 400 printer
Make sure you use original DYMO paper, otherwise the machine may be confused as to where to begin and stop. Also, cleaning the print head is a good idea if you have had the printer for a while.
The latest software is crucial. Right now it is version 8.4.2, you can see which one you have by clicking on Help > About DYMO Label.
If the above does not help, you are welcome to contact the DYMO help desk (dymo.com and select your country).
Dec 02, 2012 | Dymo LabelWriter 400 Thermal Printer
One of the blue lights will not stop blinking and the labels won't print. I am 99.9% certain the labels are in correctly.
make sure label role is pointing downwords not upwards then check to see if roller is securely snug with labels then try again.
Feb 22, 2011 | Dymo LabelWriter Thermal Printer
It begins to print then stops half way
Having the same problem here... very random... send a print job of labels and it will print the whole lot, or freeze at random points but always halfway through a label... no error message... unplug usb and replug doesnt do anything, but unplug and replug power and off it goes printing more lables but may even freeze again after only a few more have come out... also, every day the first print job of the day prints half the label and pauses for about 10 seconds then keeps going...
- Windows XP Pro SP3
- LabelWriter 400 as supplied out of the box
- Genuine DYMO labels
Jan 28, 2011 | Dymo LabelWriter 400 Thermal Printer
Dymo prints blotchy labels and feeds out many labels after print
Sounds like you have a couple of issues going on...your labels are incompatible or you have an incorrect template selected in the Dymo Software.
Check that the label model matches the template and you are using quality Dymo Labels. Such as the Dymo name brand or the LabelValue brand Dymo labels.
Apr 30, 2010 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo labelwriter 400 Turbo -We replaced the roll of labels and it keeps feeding with no stop
Oct 17, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
My dymo label writer twin turbo stopped printing on left side!
3.) the label sensor is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view. 4.) the print head is covered by some debris - sometimes a label jam can cause a piece of label to become stuck on the underside of the sensor thus blocking its view.
5.) The labels are defective - if you have another roll of the same size, try it to see if it has the same issue. If not, make sure you purchase quality labels like Dymo name brand or Labelvalue brand Dymo labels.
6.) The printer is defective. Labelwriter 400s have a 2 year warranty, so you can contact Dymo customer support to determine if the printer is defective and return to the retailer you purchased it from.
Oct 08, 2009 | Dymo LabelWriter Thermal Printer
My dymo is printing but the blue light won't stop blinking?
I have a LabelWriter 4XL with legit labels and driver on Mac. I had a flashing blue light. I had tried cleaning, cycling power, reseating the interface connection and it seemed none of this helped. Then I removed the labels from the feed and re-fed them and the error cleared.
Jun 06, 2009 | Dymo LabelWriter Thermal Printer
Zebra Z4M only feeds a small portion of the label.
You should try a factory reset. Power off the printer. Hold the "pause" and "feed" buttons down while powering up. Allthe lights will blink and when they stop blinking, release the "pause" and "feed" buttons. This will factory reset the printer.
Apr 24, 2009 | Zebra Z4M Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Continual feeding of labels?
the settings of the printer must have been changed
May 20, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
50 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
