Question about RTO Supco VG64 Digital Vacuum Gauge
I think I wiped out the calibration constants in my VG64. Can I get a clibration procedure?
What is the the valve calibration for a Honda crv 1997
I think you are referring to the clearance of the valves. Intake and exhaust valves have different clearance. There is a procedure how to do it and the tools you need.
Feb 21, 2015 | Honda CR-V Cars & Trucks
Constant LO reading on Taylor 9200
This might be due to calibration or the thermocouple is bad. You can get new thermocouples here http://www.taylorusa.com/restaurant-hospitality/thermometers?t_type=42
They also have contact info and calibration procedures.
Jul 04, 2014 | Home
Clibrate pitch Vestax PDX d3S
It's a variable , since it's depended on more parts, but just clean it first and gently turn it until the platter moves correct,assuming you
mean to correct the variable resistor(potmeter) . If the value was everywhere the same, then you don't need a variable resistor:)
Jun 19, 2013 | Vestax Handy Trax Turntable
Just bought a cobra ltd crome ive mounted every thing how to i clibrate it with my attenna? when i key up both rx/tx and ant lights up red?????
This is a common misunderstanding when it comes to communications equipment. You don't tune the antenna to the radio, but rather you tune the antenna to the vehicle. the vehicle is the ground plane for your antenna system.
With that said You will need an SWR Meter between your antenna and Radio. follow the instructions for your meter for calibrating the meter and follow the instructions for your antenna for adjusting the length.
Jul 14, 2011 | Cobra 29 LTD CB Radio
Compass direction wrong
Compass Calibration
Before calibrating the compass, drive the vehicle to an area that is magnetically clean or free of large metallic objects. Verify there are no magnetized objects on the inside or outside of the vehicle close to the mirror.
Start the engine.
Press and hold the switch for the compass, which may be depicted as COMP, COMPASS, or On/Off (w/UE1) depending on the type of mirror on the vehicle, until the letter "C" or "CAL" is displayed.
Drive the vehicle in circles at a speed of less than 8 km/h (5 mph) until the "C" or "CAL" is replaced by a proper vehicle heading. The calibration procedure is now complete.
Compass Magnetic Variation Adjustment
Magnetic variation adjustments are required when the compass displays a constant error in heading. Variation is the difference between magnetic north and true north due to geographical location.
Nov 09, 2010 | 2004 GMC Envoy
We have a digital controll that is not accurate on the oven temp....off by 25 degrees. How do we calibrate it...as in when it is 350 inside the oven, how do we set the digital control to that temp.
on most modesl this is called a clibration adjustment
most have a code that you can enter into the erc
if you still have your book, it is in the directions
most work this way
push and hold bake for 5 sec
you should get a double 00
then use the up arrows to adjust the temp
if this does not work send me the model number
ill send you the directions
Oct 27, 2009 | Ovens
It will not calibrate
Make sure you have placed printed sheet correctlyon scanner glass!
Jan 11, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error 5 for ncr 7875 scale scanner
If the scanner read only two times is a problem with the communication protocol.
What protocol do you use?
Explain more about your problem with your calibration pricedure
Jul 29, 2008 | NCR 7875
Unresponsive htc tytyn touch screen
i had the same problem, it turned out to be dust caught just under the plastic at the edge of the screen, a finger nail got it out or you could be fery careful and use a sharp flat knife. hope that helps,
Jul 28, 2008 | HTC TyTN Smartphone
RTO Supco VG64 Digital Vacuum Gauge Logo
113 people viewed this question
Top RTO Measuring Tools & Sensors Experts
jdthefixer
Steve
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
