Toshiba 3LCD Projector - No image from the computer
I am unable to project images from laptop via my projector. The green lights come on when the projector is switched and the Toshiba logo is projected on to a screen. However, the computer does not seem to be recognised by the projector or vice versa. The projector light is on but does not seem powerful enough. What is wrong ? Do I need to do something?
  • 3,037 Answers
You will need to go into your control panel and get the display settings set up.
To do this follow the detailed directions at the following link and you should have no problems what-so-ever
http://qbx6.ltu.edu/s_schneider/howto/displays.shtml
If you have any further questions please let me know, I am very familiar with setting up multiple screens and such if for some reason you have questions with the directions on the link above.
Thank you for using Fixya and Good Luck to you
Posted on Apr 19, 2008
  • Benjamin Patri
    Benjamin Patri Apr 24, 2008
    Please don't forget to rate this solution as that is one of the biggest aspects of all this website works
    otherwise please let me know if you have further questions
    Thank you
    Genius:
  • 3,422 Answers
HI,
Can you please give the make and the model no. so that i can help you fix it.
Waiting for your reply..
  • Erin Bennett
    Erin Bennett May 24, 2014
    3M MP8725 mobile projector
The image color on projection is not the same as shown in laptop. There's is no red color.
It could be a broken connection in the computer lead for the red signal, or a fault on the projector that the red panel doesn't work any more.
To diagnose, bring up the projector's on screen display. If there's white in the menus then the problem is the cable. Replace it with a new one. If the menus are affected too then it's a projector problem. This requires the attention of a service engionner.
Aug 20, 2014 | Toshiba Tdp-s25 1080i 720p Hd Dlp...
What to do with a image that is cut off?
Hi Anonymous,
Most of the time, when an image is cut off the problem is coming from the source.
I assume you are using a computer connected to the projector? Try using different resolutions in your computer's settings. If you are using Windows, right click on your desktop (away from any icons) and go to screen resolution to make the changes.
I hope this helps!
Mendtronix
Projector Lamps Projector Bulbs Projector Parts Projector Repair Servcie
Jun 03, 2014 | Epson PowerLite 3LCD Projector
Image is upside down on the screen
Alot of projectors (being all projectors that are designed to be hung from a roof) have an image flip function. This is because when you install a projector in a roof you have to flip the projector upside down so the projector doesn't have to be pointed down and doesn't cause any problems with keystoning.
If you have just bought a new projector and installed it in the roof or perhaps bought it second hand and are projecting from the floor (when the previous owner may have had it in the roof), you will need to go through the menu screen until you find this setting. I don't know exactly what Epson call this function but it should be in there somewhere. If you have it on the floor you want image flip off, if you have it in the roof you want vertical image flip on, horizontal image flip is for when your projecting onto a special screen surface from behind the screen.
Mar 24, 2011 | Epson PowerLite 3LCD Projector
Projector projects the computer onto the screen backwards
you have to either flip the projector around or flip the image around in the menu settings of the projector
Oct 13, 2010 | Epson PowerLite 3LCD Projector
What bulb is needed to replace in the projector?
three green lights come on then the standby light goes red and remains on when the projector is plugged in. The lamp and fan do not come on when the power button is pressed instead the lamp light comes on red.
Jul 13, 2010 | Toshiba TLP S30 Multimedia Projector
Hitachi projector problem
Many Hitachi projectors use 3LCD technology which supposedly makes colors more realistic. 3LCD means that the projected light must pass through 3 seperate LCD screens. Each screen has one color but when mixed, they form a nice picture. I would guess that one or more of the LCD screens have gone bad. That is a hardware problem that I would recommend talking to the manufacturer about.
Mar 03, 2010 | Hitachi Performa CP-RS55 Multimedia...
My toshiba tlp 261 won't project the image
hi try using the function key to toggle the display output form the laptop.every laptop when connected to an external display like projector works in the multiple diplay mode.in this mode the laptop vga output can be seen in 3 modes------ only laptop screen, only external deipaly(projector) & both laptop & projector.check this & this should work fine
any further help contact shyam +919867355202
Feb 07, 2009 | Toshiba TLP 261 Multimedia Projector
User manual
Solution for Sharp projector
with the function button on the laptop and the lcd button, F5 for toshiba, the screen will display both sides. if not then give the details of ur laptop.
Dec 11, 2008 | Sharp Notevision XG-C50X Multimedia...
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
Large white vertical bar thru picture during projection
Two reset attempts to factory settings seems to have been the fix.
Feb 01, 2008 | Toshiba TDP-S8 Multimedia Projector
192 people viewed this question
jasbo
jasbo
