Question about Kenmore 64672 Electric Dryer
Power outage recently. won't turn on
Suspect fuse. Where is fuse?
Powere outage recently and dryer now won't run.
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryerpower outage recently. won't turn on - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The power outage recently. won't turn on - 2_bing.gifttp://www.fixya.com/support/t4747857-the_dryer_is_not_functioning_at_all_ther#">dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 11, 2010
Amana Gas dryer runs but ingniter won't glow and gas valve won't open
That means no power is getting to the gas assembly. The number one suspect would be the fuse which mounts directly on the blower housing right next to the control thermostat.
AMANA MANUAL FOR DRYERS
My Home movies
Sep 08, 2012 | Amana Dryers
Lhe5700wo won't heat after power outage
the heating element may have burnt out , you can purchase on for around $25 dollars , also check thermostats, I usually find where the heating element has burned into, then spice it back together with a stainless steel electrical **** connector , check with ohm meter . heating element runs in a metal box shaped container and looks like a spring coiling through ceramic insulators .
Mar 13, 2012 | Dryers
We a Kenmore Elite clothes dryer (Model # 110 70972990). Monday there was a power outage that happened while the dryer was running. Hours later when the power was back on, we tried to finish drying, but...
There is a thermal fuse. If your lint filter is on top of the machine it is in the rear of the machine behind the removable panal near the exhaust port. If the filter is in the door the fuse is behind the kick plate on the top of the blower housing they are usually white plastic. But a power outage won't blow the fuse
Oct 19, 2011 | Kenmore Dryers
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
Dryer won't start - is plugged in and all home fuses are working. Could be an interal fuse that was fried during a power outage. How can I check that?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Maytag Neptune dryer flashes an 88 when I push the start button, there is nothing in the manual about solution codes
lack of power did you recently have a brown out or power outage that may have messed up the breaker in the fuse box box
Aug 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
FUEL LIKE ORDER COMING FROM ELECTRIC DRYER POWERE BY FUSES
Have you recently painted anywhere in your home. And I mean anywhere? Paint fumes or other chemical type cleaners or solvents will get in the elements and put off that whole gas or oil smell. If no, have you put any type of clothes in the dryer that may have had some paint or anything else petroleum based on them to dry. That also could have caused this smell as well. If your hot water heater runs on propane or natural gas, check it careful for leaks. This could be a serious situation as a major explosion could happen if it is leaking. Leave the house and call 911 immediatly from a safe distance. I doubt that this is the problem, but be safe than sorry. Let me know if none of these are the culprits. Thanks and let me know.
Feb 22, 2008 | Whirlpool LER5636P Electric Dryer
We had 3 power outages a couple of days ago and my Maytag Performa Dryer won't run now.
Obviously when you had the power outage the voltage and frequency fluctuated. If you had the dryer running at the time, then it has tripped. Check the power supply at the plug point first, if its good then check the machine it has to have a trip switch on it or a internal fuse. check them if they are good.
Jan 10, 2008 | Dryers
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Kenmore 64672 Electric Dryer Logo
149 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
