Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw starts OK, but quits when excellerating.
Worked fine one day, but next day it started as usual, but would quit as soon as you accellerated. I could kinda keep it going by choking it. Filter is clean, plug has good spark.
  • 6,674 Answers
Check line to carb form fuel tank for blockage/restriction.
Posted on Jul 10, 2010
Testimonial: "Good Suggestion."
Have a st800 Stijl partner saw that was running fine then next day won't start
quite possibly wrong gas mixture was used . they do not like no or too little oil in the gas
Jul 03, 2015 | Garden
What causes loss of excelleration while driving
It sounds like either your fuel pump has quit or your fuel filter is badly plugged. If you crank it for a while and do not smell gasoline back at the exhaust, your fuel pump has probably quit.
Nov 27, 2014 | 1994 Ford Escort
I replaced the fuel pump on my 2002 sunfire. It worked great the first day. The next day i needed a litre of oil so i put it in, then when i start the car it will idle but ruffly or stall. So when i put...
yes there is a trottle position sensor.
but first have engine code retrieve if any
if it run rough idle we don't talk tps
spark plugs, wires,fuel pressure if it's good alot of to do
if you have a scanner you could see the data
Oct 07, 2013 | 2002 Pontiac Sunfire
Starting, idleing problems
Auto idle module may be bad or the idle valve on the engine may need to be cleaned.
Jan 30, 2018 | 1995 Jeep Grand Cherokee
Car stalls while driving. Will start after about five minutes. Is not flooded. Doesn't usually do this until after it has been driven a bit. Does it more in warm weather. Check engine light sometimes...
I'd have fuel pressure tested. I had a 95' did same thing. Cold winter day, worked fine, as soon as it got warmer, or hot out, it would quit, and re-start 20 minutes later and go for a distance then die again. If I parked in the shade on a hot day, I'd get further before it quit for the first time. I started carrying a fuel pressure gauge with me. Cool in the morning my fuel pressure was up to spec @ 49-50psi. Once it got warm/hot out and it died, Hooked up gauge and it was at 2-5psi. Let it sit and cool off 20-30 minutes, pressure would jump back up and run good until fuel pump got hot again and then pressure dropped off and car quit. It sure sounds like the fuel pump, but the hard part will be getting the car to the shop at the right time, or they will need to let it run on the lot until it quits to confirm the pressure drop. One thing you can try is when car quits, have a can of WD-40 or quick start with you and a screwdriver. Loosen the clamp on the air intake hose where it connects to the front of the throttle body and pull it off. With vehicle off, turn throttle linkage so the plate opens up enough to spray WD-40 a second or 2 in the throttle body. Then try to start it. If it starts and runs momentarily, then you can be pretty sure it's fuel related and my guess is the pump needs replacement.
Apr 12, 2011 | 1996 Plymouth Neon
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Fuel problem
Not to sound silly but #1 are you sure its a fuel problem and #2 have ypu changed the fuel filter?
Jim
Oct 04, 2008 | 1995 Chevrolet Blazer
Sound quits after game loads.
are you using original xbox games or 360 games
Dec 16, 2007 | Microsoft Xbox 360 Console
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
170 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
