Question about Whirlpool AWM8123 Front Load Washer
Whirlpool Duet washer fills with water when not being used and pours out on floor. I normally leave the door open on the washer so it can air, but sometimes it will just fill with water and pour out the door, what could be the problem
  • 15,935 Answers
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Apparently my washingmachine filled up with water after i used it. it was off and i always leave the door open to prevent the smell of mold. so i need to clean or possible replace the valve in it? It not...
You already have the answer.. Yes. Replace the water valves.
Temorarily, you can shut off the water at the faucet end of the hoses. tuen on to use, turn off when done..
Your problem will only get worse.. so don't leave too long.
Here is customer service http://www.whirlpool.com/custserv/index.jsp for ordering parts maybe directions too.
Mar 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water pours out of the front door onto the floor..a lot of water. Only had this for a little over a year.
You may need to replace your pressure switch if the water is filling up to the glass in the door.
Aug 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of the bottom part of the washer door.
If your Whirlpool FRONT LOADER is leaking, the following link can give you guidance on how to inspect the washer to determine where the source of the leak may be coming from:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
Most commonly, the source of the leak comes from the door bellow (gray rubber seal). They do wear out with age and can develop small rips and tears. A routine inspection of the perimeter of the door seal can determine if you have any holes. If the seal is damaged, it must be replaced. The following link explains how:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
The manufacturer recommends that you leave the washer door open between washes to prevent the seal from becoming permanently stretched. Once the seal stays compressed constantly it can stretch and not seal properly. In addition, leaving the door open helpd let the wash tub air out and prevent mold, mildew and musty odors.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Jul 10, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My whirlpool duet washer is filling with water when it is off. it only drips, but two days in a row it was filled up above the bottom of the door openeing and spilled on the floor,
This problem is either attributed to a defective water inlet valve, or defective pressure switch. An easy way to determine which one may be causing the problem is to unplug the washer, but leave the water taps on. If the washer continues to fill, you have a defective water inlet valve. If the water stops, I would recommend changing your pressure switch.
Post back and let me know if you require further assistance. I hope this helps you.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water filled the tub above door seal when not running or turned on. Poured out when door opened.
most likly you sucked something into (auto) water leveler, try unplugging unit and check drain hose,also drain hose HAS TO DRAIN "UP" ATLEAST 36 INCHES, off of floor into sewer line, or it will back up into washer,thus not completely emptying last cycle, let me know if this helps,god bless
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When machine is not in use, with door open, tub will have water
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer smells like stagnant water
Open the door and let it air dry between washes doesnt have to be wide open but not latched either also run a hot wash with no clothes and 1.5 cups of bleach (pour bleach in the tub after it fills not in the bleach disp)
Sep 28, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool AWM8123 Front Load Washer Logo
257 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
