Question about Canon imageCLASS MF6550 All-In-One Laser Printer
Canon MF6550 Hello, Nothing halp... 10 minutes OFF... reinstallation... unplagging... My copier/printer prints blank pages! Thank you!!! Irina Schmidt NewYorkNotary@gmail.com 607-229-6817
  • 1 more comment
  • Anonymous Sep 08, 2008
    Yes I had the same problem.
    I have replcaed the toner. Did not work.
    Then I hit the printer left, right and top then, miracle- it worked.
    Thank you guys
    I responsibly tried making sure that I was properly inserting the printer cartridge and closing the door tightly. Then I replaced the printer cartridge. Hours later, I began beating the life out of my machine as recommended, but it's still not working. What else can be done besides throwing it in the dumpster outside? FYI...I've had about ten of these Canon machines in the past 5 years at my office and probably 3 of them have died this way. 3 others have died when the papers stops feeding properly and starts jamming. It just becomes not feasible to keep having them serviced instead of buying a new one.
  • dchristolear Oct 31, 2008
    I've tried everything mentioned. No luck. The laser flap has, about, 1/8" open. I flipped it open over & over. Guess I'll take to service. Still under warranty but, the closest repair is 95 miles away. I won't ship this monster. Who knows, maybe the jolt from shipping would do it:-).
1. Remove paper tray.
2. Reach inside copier & tap upward using a medium sized flashlight. (Or other object approximately 8" x 2")
After about six upward taps, my copier is working perfectly.
Posted on Feb 04, 2010
I've tried everything before for months... unplugging, new cartridges, servicing, etc. I've always avoided jarring an electronic item, but hitting the front fixed it! A couple of open-palmed smacks above the paper drawer, and it printed this very page. Apparently, sometimes the cover over the laser sticks shut after replacing the print cartridge, or removing a paper jam. Sounds crazy, but smack it!
Posted on Jun 16, 2008
  • 22 Answers
Try putting the cartridge in and sliding it to the right to make sure it is making a good connection. Try to make sure the cartridge door is shut firmly as to open the Laser shutter which allows the laser to write to the drum.
Posted on Apr 22, 2008
Replaced a printer cartridge type 106 with same. Everything was done according instruction. The printer printed several pages and now will not print anything but a blank page. what needs to be done to...
Check to see that the toner cartridge does not still have a "Pull Strip" on the cartridge. or Remove the cartridge and gently rock the cartridge a few times in your hands and re-install.
Jun 25, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
CANON IMAGE CLASS MF6550 PRINTS BLANK PAGES
the lase unit windows is block. It has a metal windows that for some reason sometimes stay clouse. just but a tape to hold it up or remove LSU and take out that metal part.
May 04, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
WHEN RESETING PRINTER IT PRINTS BLANKS AND WE ARE HAVING TO CONSTANTLY HAVING TO REMOVE THE INK AND TURN ON AND OFF THE PRINTER
After you reinstall the toner cartridge does it print? If it remains blank you may have a stuck laser shutter. The toner cartridge needs to open the laser shutter when it is installed and sometimes the mechanism gets off kilter and needs to be straightened out.
Jan 15, 2010 | Canon imageCLASS MF6550 All-In-One Laser...
Canon ImageClass MF6550
Does it recognize the device being attached (usb being plugged in)? If not uninstall and reinstall printer software and drivers
Apr 25, 2009 | Canon imageCLASS MF6550 All-In-One Laser...
Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
Aug 19, 2008 | Office Equipment & Supplies
Canon imageclass mf6550
If the paper feeds through but nothing is on it, it indicates that the toner is not being properly fed. Go to this link, type "printout is blank" in the Search window and click the search button. Next, click on the "Printout is blank" line, and review the document. Especially check that you have removed the seals from the toner cartridge (see steps 7 and 9 on the second part).
May 06, 2008 | Canon imageCLASS® MF6550 Laser Printer
How to locate the printer head for model mf5500
The Canon MF5500 series are laser printers. There is no print head. If your pages are coming out blank, check that you have sufficient toner. If you have toner, then the machine may require service.
Canon Image class MF6550
contact them, ask for a refund or a replacemnt. This is the first time Im seeing a company use the same model number in more than one product. Im very sorry.
Apr 19, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Paper comes out with nothing on it
Possibly sounding silly here, (again) but have you removed the seal from the toner cartridge (This is a breakaway plastic tab, connected to a length on plastic, which seals the toner for transit)
If this has not been removed from the cartridge then it fails in just the way you are describing
Oct 15, 2007 | Canon imageCLASS MF6550 All-In-One Laser...
Canon imageCLASS MF6550 All-In-One Laser Printer Logo
542 people viewed this question
old marine
old marine
