Question about Kenmore Dryers
My Kenmore Elite dryer will not heat. It tumbles
My Kenmore Elite dryer will not heat. It tumbles and has air, I have cleaned all the vents and changed out the thermal limiter - what else can I try?
  • 78 Answers
REPLACE THE ELEMENTS, YOU CAN CHEC THEM WITH AN O METER TO SEE IF THEIR NORMALLY CLOSED AND NOT OPEN, BUT I WOULD THINK THIS IS THE PROBLEM IT USUALLY IS
Posted on Jul 12, 2010
Kenmore Elite Oasis ST electric dryer does not heat
You need to replace the heating coil that is usually the problem when you get air and and the tumbler is moving but no drying you can also check the lint catcher and clear out your dryer outgoing vent remove the hose check the dryer vent where the vent hose is connected and the vent going outside the house before changing the heating coil .
Sep 04, 2014 | Kenmore Elite Oasis 6808 Electric Dryer
Hello! Yesterday we cleaned out our home dryer vents. Today the heat wil not come on in our kenmore elite dryer. It tumbles and blows cool air, just no heat. Suggestions? Thank you!
If you have a gas dryer, your problem is probably caused by the ingition panel.Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty.If this helps solve your problem, please come back to Fixya and rate my advice
Jul 25, 2011 | Kenmore Elite HE4 Electric Dryer
Sears kenmore elite oasis dryer 110 67032600 check lint screen flashes doesn t heat
Check the vent on the back. This is indicating a air flow issue. If the vent is clear ohm the heater out check it for continuity.
You can watch a video that explains how to complete this repair on your sears Kenmore Elite clothes dryer at the link below.
Sear Kenmore Dryer Video
Mar 11, 2011 | Kenmore Elite Oasis ST 6807 Dryer
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Not drying clothes - have heat and tumble but probably not air Kenmore 80 series dryer.
Your vent is clogged. Remove hose from back of dryer and wall. vacuum out back of dryer, dryer hose an vent pipe in wall, if it goes out at roof you will need to clean out. Moisture from dryer is getting caught in excess lint trapped in vent causing dryer not to dry.
Sep 20, 2009 | Dryers
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
My Kenmore Elite HE3 Dryer is not drying. It does not seem to produce any heat. The dryer does start as usual, lint screen is clean. Help!
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 16, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer - Ignitor will not fire
thanks for the question The problem is with a thermal fuse located at the back remove back panel the thermal fuse is located on the air vent 2 small wires go to it replace it . And check the venting make sure the vent is clean because this termal fuse will break down because of poor venting Thanks for the question The appliance doc
May 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
168 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
