Question about Kenwood VR-407 Receiver
Kenwood vr 407
Wont' play DTS 5.1 surround even with cable box and DTS 5.1 DVDs (fiber optic cable hook-up). Only plays in Dolby Digital, or stereo. All surround speakers hooked up and test fine on the various channels. Subwoofer plays during test, won't play in DD or stereo mode.
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
DTS option shows on the display when playing a DTS movie, but unit will only play in Dolby when trying to select listen mode...I can't select DTS mode
That is a typical function of the movie you are watching..changing the sound mode can "usually" only be done by selecting it on the disc, or by using the audio button on your player depending on the model.
Dec 23, 2009 | Kenwood VR-407 Receiver
Does kenwood VR-405 play DTS-HD Master
I have the 405 and a Samsung 3600 which has onboard DTS Master/ Dolby True HD. Out of the 6 movies I 've watched, only 2 have given me Dolby Digital. Bottom line: If the movie doesn't have DD, you cant get DD on the 405. I thought just about all blu rays had DD but its not so. Its time for us to upgrade!
Oct 24, 2009 | Kenwood VR-405 Receiver
Kenwood VR-407 always stays in Stereo mode
You will need to go to audio set up and make sure it is set up to play with a center chanel if you have one as well as the surrounds. You can also only have side a speakers selected when trying to use surround. If you have b selected it will play in stereo only
Jul 26, 2009 | Kenwood VR-407 Receiver
Unit does not detect/play dolby dts/5.1 from DVD
make sure that the the DVD setting on your reciever is set to look for the the fiber connection (if it is not looking at the coorect input it will not work)
Oct 04, 2008 | Kenwood VR-309
RCA RT2280 surround sound mode button wont select 5.1 dolby digital mode.
I had the same problem and this is what I did to fix it. Assuming that all of your equipment is powered on, (tv, blu-ray/dvd, rca receiver) you'll need to go into your dvd players audio menu and select the dolby digital audio.
Once you do this, the digital signal is sent to your receiver from the dvd. The receiver should automatically set itself to the dolby digital preset. If it doesn't, press the surround button until you reach it. I found part of this information here. And the rest was personal experience.
Also, it depends on if the disc format is in dolby 5.1. I hope this helps you.
Dec 18, 2007 | RCA RT2280 System
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Kenwood VR-407 Receiver Logo
212 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
