Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Chlorine light does not come on - Intex Automatic Salt Water System for Above Ground Saltwater Pool
  • 297 Answers
After setting your time it will take up to 10 minutes for the second green light to come on
Posted on Jul 10, 2010
  • mark Gianotto Aug 09, 2010
    would have been nice of you to use the rating system after the help you received!
Zodiac ei series salt levels are fine cannot increase chlorine indicator light above 20%
need more info is this connected to a system if so you have to change it in the system if not on a system sounds like a bad control board
May 19, 2014 | Zodiac Nature 2 Cra30 Replacement...
24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Apr 01, 2013 | Intex Automatic Salt Water System for ...
The intex system light is green ,but when i test water no free chlorine is registered
I have an 18 X 33 X 48" oval pool (14000) gallons and I run my pump in the summer months at 10 to 12 hrs and chlorinator at 8 to 10 hrs of those pump hrs and hit a chlorine level at 2.0 to 2.5 ppm.. Green chlorine light means you are generating, it does not mean you have the correct level.. Increase your cycle time and check after 3 days... Please post a comment if this helps! Good luck,,
Aug 08, 2011 | Intex Automatic Salt Water System for ...
All lights are on and everything appears fine but the unit does not appear to be producing chlorine. Have had unit on for two weeks but testing shows no chlorine . Salt level is fine and unit is only in...
I am not an expert on the Duoclear but I have had mine for 5 years and have not had any problems. This unit and all salt water systems will not generate chlorine when the water temperature is below 65 degrees f. I am not saying that this is why yours is not generating chlorine, just commenting in case you were unaware.
May 25, 2010 | Zodiac Duo Clear System Chlorine...
Intex chlorine generator no working
check sensor if ok cell or check voltage to cell
Jun 14, 2017 | Intex Automatic Salt Water System for ...
No warning code, green light on but no chlorine produced???????
make sure your ppm is at least 3000 low salt may not trigger an alarm but is not sufficient for generating chlorine
also make sure you are running the generator for at least 4-6 hours to give the chlorine time to register
the system itself blows out very minute amounts of chlorine but build up after hours of being on
Jul 20, 2009 | Intex Automatic Salt Water System for ...
No green light....no chlorine generation
make sure you have at least 3000ppm of salt content'
set your timer for generation - the green chlorine light will not come on for at least 5 minutes sometimes up to ten
make sure you run the generator for at least 4-6 hours the first time
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Salt light flashing added salt light went to orange no longer flashing but no chlorine lights will light has been 29 hours
All salt generators need at least 4-5000 parts per million for up to 30 days for the generators to re-generate salt. it takes chlorine to combined with the generator and salt to regenerate salt. Salt generators do not make salt from water that is not chlorinated first.
Try This and you will re gererate chlorine.
The Pool Tech
Jul 16, 2009 | Zodiac Duo Clear System Chlorine...
DuoClear 25 doesn't chlorinate well, chlorine output lights
have water checked see if chlorine is locked that will act like chlorinator not working also crack output union so water drips out test with strip if chlorine oxidize water if no chlorine unit not working
Jun 12, 2009 | Zodiac Duo Clear System Chlorine...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
205 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
