Question about Fujitsu LifeBook A6120 Notebook
Hello, i have a Fujitsu A6120 laptop and the options for adjusting brightness (thru control panel and manual adjustment by key-function) are not working. the brightness is just set to maximum. I?d like to lower it down since work for long hours in front of computer. Hope you can help me.
    President:
  • 2,571 Answers
Either adjust them with your graphics cards control panel(right click desktop and screen setting should be there, or from the control panel)
or adjust it through the power options menu in control panel
Posted on Jul 10, 2010
My Fujitsu lifebook T902 keeps changing the screen brightness levels for no apparent reason.
I would think that if the virtual level controls are not changing, either the power socket/supply, back light or invertor has an issue.
Dec 01, 2013 | Fujitsu LifeBook Computers & Internet
How do i adjust the brightness on my HP6710b. I normally do it with fn key but that aint working?
Generally, the function key only works when you are running on battery. you can adjust the brightness at the power options. Go to start, control panel, power options, edit plan settings. Move the slider to adjust your brightness.
(Windows 7; similar in other Microsoft systems)
Sep 18, 2011 | HP Compaq 6710b Notebook Pc
How do i adjust brightness in hp g60
Here's how to adjust the screen brightness for a laptop in Windows 7:
  1. Go to Control Panel -> Hardware and Sound -> Power Options.
  2. Click on "Change plan settings" for your laptop's selected power plan (either Balanced or Power saver).
  3. Now edit your plan settings by moving the sliders next to "Adjust plan brightness" at the bottom. You'll be able to change the brightness for when your laptop is On battery power, or when it's Plugged in.
  4. Once you've adjusting the brightness settings to your liking, then click on the 'Save changes' button.
Alternatively, here is another way: From the Windows desktop, hold the fn key and press the f7 key c00776226.jpg to increase or the f8key c00776225.jpg to decrease the brightness of the display. If using the function keys does not resolve the problem and you have a Lid Actuator on your particular model, check the movement of the Lid Actuator switch to determine that it moves freely and is not stuck. NOTE: The key numbers (f7 or f8 ) may vary depending on the notebook PC; however, the images on the keys should be similiar. If you reboot the PC after using the function keys to change the LCD brightness settings, the brightness may return to the default setting on some models, which is based on the power source-battery or AC. This is not an error. The notebook is functioning as designed. If the notebook returns to the default setting after rebooting on your particular model, use the function keys to change the brightness back to the desired settings.
Aug 23, 2011 | HP G60-120US Laptop
The brightness of my laptop is very high
There should be a function key (usually labeled "FN") on the keyboard. There will probably also be buttons with brightness adjustment labels on them. Usually the arrow up/down keys adjust your brightness while the FN key is pressed. The adjustment keys are usually labeled with a picture of the sun with an up or down arrow beside it - almost always in a different color than the letters on your keys [maybe light blue?]. Otherwise you may have to adjust it via software in the control panel. Good luck.
Apr 05, 2011 | Computers & Internet
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How can i adjust the brightness of my laptop aside from using function keys.i cannot adjust it even using function keys..it doesn't work.
You can access this setting from the control panel as well. The steps may vary depending on your operating system.
1. Go to the Start Menu 2. Access the Control Panel 3. Select the Display 4. Browse the window for the Adjust the brightness options (For example, I am running Windows 7 and it is on the left side of the window)
Mar 17, 2011 | Samsung Computers & Internet
Display to dark how to adjust.
in most cases there is a function key combination on your keyboard for adjusting the monitor brightness. look for the function key (f) and another key with a "*+-" and press them at the same time to increase or decrease the brightness.
also in your advanced display property settings in the control panel there is a driver level brightness and gamma adjustment that can be used.
Apr 01, 2010 | Acer Aspire One PC Notebook
I have a compaq r3000 laptop computer. I need to
Select Control Panel - Hardware and Sound - Power Options ... Or, there could be a function key (press Fn and one of the F1 - F12 keys)to adjust brightness and contrast.
Jun 13, 2009 | HP Compaq Evo Notebook N600c
We have an Acer Travelmate 4200 and the screen is too dark how do you brighten the screen??
Most laptops have a function key (F1-12) with a picture that looks like a sun. Press and hold the FN button and the appropriate Function key. You should get a "slider" to adjust the contrast and brightness..
Some laptops also come with a program to make other display adjustments. Look at the Control Panel to see if you have one of those on your list. If not, check the "Display" application on the Control Panel, and under "Settings" see if you can adjust contrast or brightness that way.
Jul 21, 2008 | Acer Computers & Internet
Fujitsu LifeBook A6120 Notebook Logo
314 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
