Question about Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive
HD-CEIU@ I am having trouble plugging in the firewire adaptor into the port on the drive station. I have the HD-CEIU2. It has always been a little tricky plugging it in- but, now it just does not seem to fit. Same plug that has always fit in there. And, all that I did was just unplug the firewire. When I tried to plug it back in- it just wouldn't fit. Certainly a low tech problem- but it has me stomped. I know that I was not rough in unplugging it- rough enough to to ruin the input. By the way, if you do not have a solution- Does anyone have any idea how much money it would cost to replace the port on this unit? Unfortunately, finances are a concern for me. I bought the unit for $100. Thanks in advance for any help you may provide.
  • 162 Answers
Did you check if the Firewire cable is causing the issue? You can try changing the Firewire or iLINK cable and check if the same issue persists.
Posted on Jul 10, 2010
Testimonial: "Thanks! Would you believe that I figured that out myself. But, you were right- it was the firewire cable. Your input was most welcome!"
  • raaghz Jul 11, 2010
    That's great!!! Feel free to contact me for any assistance.. You can write to me at raaghz@aol.com
How to connect firewires of the HD?
You just need to plug one end of the firewire (IEEE 1394) cable into the external hard drive and the other end in the slot on the computer marked IEEE 1394. Sometimes you have a IEEE 1394 slot on the front panel, and sometimes it's just on the back of the PC.
If you find you don't have a firewire (IEEE 1394) port on your PC then you will need to get adapter that will change the firewire to a usb. If you have trouble finding one of those then install a card like this in your desktop:
http://www.newegg.com/Product/Product.aspx?Item=N82E16815124002&cm_re=usb_to_IEEE_1394-_-15-124-002-_-Product
Jun 21, 2012 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
I have a Firelite Smartdisk External 60G hard drive - Model #FWFL60-N which I bought to back up my previous MacBook. It only has FireWire outlets and cable with only FireWire ends - no USB port...
Hi Selina It was a big mistake for Apple to omit the FW port on the white MacBook. The problem you hilite is the reason I don't recommentd the macbook to any of my clients. However, the problem is solveable - although you may/will have to do some breaking and entering.
There is no cable adaptor - nor will there ever be, the protocols are so radically different that they can never talk to each other.
The simplest option is to connect your drive to another mac that has got FW (800 or 400 - it doesn't matter as long as the cable will connect the two units) then use file sharing to transfer the conent of the drive to you MacBook either by ethernet (preferable) or by wifi (much slower).
The breaking and entereing option imvolves opening up the firelilte and removing its HD (it's easy) then get a unit like this Overview or this http://www.maplin.co.uk/sata-hard-drive-usb-docking-station-222999
There are other much cheaper units and they all work fairly well. I have several as I'm up against your problem regularly
Apr 01, 2011 | Computers & Internet
Got a 5-year old Lacie 160 gb that had been used as a Mac backup.
This external hard drive is a firewire and if your laptop does not have firewire ports, then you can't use
it, but if you have a desktop, then there are solutions to your problem in the form of a firewire card.
There is no such thing as an adaptor for a firewire cable, since firewire is an entirely different technology
than the ports your PC presently has.
Firewire is an extremely high speed technology which exceeds the speed of usb and other kinds of ports.
You can get a firewire card for as little as $13.00 here
Apr 09, 2009 | LaCie (300740) 160 GB Hard Drive
Firewire 800 cable
No such thing s a dumb question, I transfer from my Canon XL1 to my Mac IBook with firewire all the time. You have three choices: 1. Buy a cable with two different ends - one that will fit your camera (the tiny one so small it is hard to insert) and one that will fit the Mac. Your Mac should have two different types of firewire ports - the semi-round one and the square one that looks like a USB port, but isn't. The symbols are different  for firewire ports firewire and USB ports. But all firewire ports, regardless of the configuration will have the firewire symbol and all USB ports will have the USB symbol.  Either firewire symbol port will work. I have two different firewire ports on my MacBook G4 and use them both,  I keep a bunch of firewire connectors around. They usually come with outboard hard-drives in various configurations. Sold en Ebay or at computer stores Solution 2: Feed your firewire through an outboard drive that will accept the 400 firewire (many do) and then take another firewire, say an 800, from that drive into your computer. I always capture to a hard drive then edit from there. The idea of a firewire bus is that you can connect a number of drives in parallel and mount them all. Available for as little as $69.
Solution 3: Buy a firewire port card for you MacBook which slips into a slot on the side, and gives you connectivity with the 400. It also frees up your main firewire port. I bought one on Ebay for $24 that came with all the adaptors. I was pulling my hair out too until I figured out the system.
Nov 28, 2008 | Sony DSR-11 DV / Mini DV VCR
Canon vixia hv 30 not recognized by computer
This camcorder uses USB for pictures only. To access pictures, plug in USB cable, set the camcorder to Play and to Memory Card.
To transfer video you need a firewire cable and card. Actual cable will depend on connection your computer has, typically it will be something like this: FireWire_cables.jpg
Additionally, to transfer video you will need a video capture software and codecs, unless the software has the codecs (Nero does). Unfortunately all free video editing software I tried was unable to deal with HD. I had various levels of success with Windows Movie Makver, Ulead and Nero.
You may want to record video in non-HD, and see if you are able to capture that. If your computer can capture that but not HD, and you have the codecs installed, you will need to investigate your computer.
If all you need is a codec, here is a good free candidate: K-Lite Mega Codec Pack
It is of course very frustrating that Canon would include nothing with the camcorder to assist users with video caputure.
Nov 16, 2008 | Canon VIXIA HV30 DV Camcorder
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Transferring mini dv to pc hard drive
You will need a firewire cable and a firewire input (IEEE 1394 port) on your PC. If you don't have the port on your PC, you'll need to buy a peice of hardware for your computer.
May 22, 2008 | Video Cameras
USB Connection Problems
You say have a SanMax HD-338-CB USB/Firewire External HD with a 160MB drive. You then say sometimes I have to reboot Windows XP pro 2 or 3 time before I see the drive using a USB 2.0 connection. Fire wire is a different system with a different connector style- so it should not be in a USB port or a USB connector should not be in a Firewire device. Get you device and connections sorted The desktop display simply puts up a device it will not differentiate which USB or Firewire
May 23, 2007 | SanMax 1 Bay (HD338CB) FireWire (IEEE...
Buffalo Technology DriveStation HD-HC500U2 500 GB USB 2.0 Hard Drive Logo
114 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
