Question about Garden
No power when switched on.
Have a flymo turbo compact 330. No power when safety button and lever pressed. Fuse OK. Occasionally hear a ''click '' of the ?motor when button and lever pressed but basically silence. Thanks
  • 63 Answers
Sounds like the engine isnt getting the power to turn it sorry but flymo mowewrs are a pain to repair as they some times cost more to do than buy a new one
Posted on Jul 24, 2010
Flymo power compact 330
test your actuator. I see this a lot on walker machines
May 17, 2014 | Garden
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
the upper section of the grass collection box is a fill indicator. this indicator shows green and turns red when full. it also triggers a power off switch. it sounds like some debris has caught between the switch and indicator.
with a fine dry small paint brush or cotton bud clean around the switch .
Switch for hover mower 300mm 1250w
Hi and welcome to FixYa, I am Kelly.
Can we get a Make and model number please? I am searching for any brand of hover mower that is 1250W at the moment and there are at least 3 different brands:
This is the Flymo manual:
http://www.shop.flymo.co.uk/images/mediator/397/oipl2002_p0201018.pdf
This is the switch for the Flymo Hover mowers:
http://www.espares.co.uk/part/lawnmowers/flymo/turbo-compact-330/p/1116/283/116/402362/1136941/8a-250v-lawnmower-switch.html
This was my best mind reading guess. If this is not your brand then help us help you by responding with a make and model number please.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Garden
Flymo Turbo Compact 350 - no power when safety button and lever pressed
My name is Dane and I am going to assist you in solving your problem.
You will need to adjust the high speed setting on your Carb jet. Turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the carb, however you do need a special tool that is very hard to get your hands on, in order to adjust the jet screws. They don't make many engines with plain screw heads anymore. The newer Carbs are factory set lean so they can pass emission standards. If you have a local dealer they should adjust the mixture for a couple of bucks.
Before you take it in though, make sure you haven't left old fuel in it for a long period of time and gummed those jets up. Sometimes they just need to run in order to clean the jets out. If this is the case, just replace the fuel and get it running and work it normal for a tank of fuel if you can.
I hope I've helped. If you found this reply useful, please leave me some THUMBS UP, if you feel I've deserved them. Thank you! Dane
Dec 06, 2010 | Husqvarna Garden
I have a s320 auto and the gear lever is difficult to move from park to drive this has started a couple of days ago any advice
first get in to the car close the doors and shutters switch off radio and a/c then witch on ignition, when you press the brake can you hear clicking sound in shift liver, release brake and do press it again and listen, if you can clearly hear click sound, it's mean brake light switch is OK. could be faulty safety release lock in shift liver control, if can't hear clicking sound in shift liver first check the brake light switch.
Nov 19, 2010 | Mercedes-Benz S-Class Cars & Trucks
Dryer has power but wont run when i push start button
Problem is either the door switch or the safety thermal, fuse,. Open door and manually push door switch lever to see if you hear a click when depressed. If you do then the problem is the safety fuse located on the blower housing. Small white plastic piece with 2 wires going to it. Hope this helps. Rick
Mar 09, 2010 | Whirlpool Dryers
My lawn mower doesn't start -all wires and cords are ok - and then sometimes it starts itself and when i move it it stops again. it was working perfectly fine one day and then the next....its gone it's a...
sometimes you get an internal break of the electric feed cable which shorts out with movement and gives problem that you are having , another fault with them is that the switch has a safety machanism in it which can cut power for up to twenty minutes before it will reset which is done by operating lever as you would normally ,occurs a lot with m/cs used with adittional extension cables,hope this helps
Mar 23, 2009 | Electric Lawn Mower
Garden Logo
855 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
