Question about Dometic Rooftop RV Air Conditioner
My 25feet airstream a/c is not cooling, but blowing worm air.
I have been told i need to buy a new a/c. this unit is sealed and can not be recharged
  • Dometic Master
  • 6,674 Answers
True they are a sealed unit. Depending on age, it's usually smarter to replace it, than have a technician, install fittings to recharge, and no warranty.
Posted on Jul 10, 2010
How do i fix the sensor that controls the blowing of the air conditioner and fan.
its supposed to only blow hi on a/c,youneed to recharge the system
Jun 23, 2015 | 1994 Ford Mustang
My 19 ft airstream's Penguin duo-therm a/c unit just started blowing out HOT air!!!! Why is this occurring?
If you have a heatpump model a/c unit, and it is blowing air that is hotter than the ambient temperature inside the airstream, then it is likely that your reversing valve is stuck in the open or closed position. A heatpump is basically an air conditioner that will also run in reverse (via the reversing valve) in order to heat instead of cool. The valve can get stuck for a variety of reasons, including; faulty wiring caused by rodents chewing or vibrations, insulators (dirt) between switch surfaces, or it could be a mechanical problem within the valve its self; these valves break often.
Sep 12, 2013 | Dometic Heating & Cooling
2007 dodge nitro not blowing cold air
The AC compressor may need recharged, or repaired / replaced. A lot of times what happens is through the winter AC units aren't ran so the seals recieve no oil and dry out letting coolant escape. Sometimes you can get lucky and a recharge (which contains oil essential for your seals) will do it - if they are too dry however, you will need a new compressor. You can have your AC unit recharged at nearly any dealership except in the state of California. Hope this helps.
Mar 27, 2012 | 2007 Dodge Nitro R/T New Cars
WOULD LIKE TO KNOW IF THE FRIEDRICH SH15L30-B UNIT CAN BE RE-GASSED, AIR CON UNIT IS NOT COOLING DOWN ROOM, FAN AND COMPRESSOR SEEM TO BE WORKING, BUT HAVE BEEN TOLD THAT ITS A SEALED UNIT AND NEED TO BUY...
It is true that it is a sealed unit and should never need charged with freon unless a leak has developed. Most service techs will tell you that they cannot be recharged because you do have to break into the sealed system with a solder in valve or a line tap. They hold such a small amount of freon that finding and fixing the leak can be next to impossible and time consuming. Make sure that the inside and outside coils are clean. The outside fins can be brushed with a semi-soft brush like a toilet brush and then washed out with water. Make sure your power is off first. If the coils are dirty it will act just like it does if the refrigerant is low. 75 to 80 percent of air conditioner service calls are solved by cleaning the outside condenser coil. Brush up and down and do not put so much water pressure on it that the cooling fins start bending.
Jul 05, 2010 | Friedrich SH15L30 Thru-Wall/Window Air...
Can my duo-therm air conditioner on my rv be recharged?
These unit can be recharged. 134A. You NEED A SERVICE TECH THAT KNOWS HOW TO CHARGE UNIT.RUS
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
Not getting any cool air
Unit works good? Is the compressor coming on but not blowing cold air? If the compressor is running but not cooling, then the main issue is usually with cleanliness of the condenser. Wash it out if this is the case. If the compressor is not coming on, multiple problems could be the reason.
These units do not have service ports as a normal AC does. If you have lost freon then there is a leak in the system somewhere as they are sealed. The process for recharging a rooftop unit is usually expensive and not fail safe. I would recommend a new unit if a leak is discovered.
May 22, 2009 | Coleman Mach III Air Conditioner
Air conditioner blows cool air but it does not blow cold air.
Start by recharging your system. If you want to do it yourself. Most auto parts stores and hardware stores have recharge kits. Purchase a kit with a gauge to prevent overfilling.
Jul 26, 2008 | GMC Jimmy Cars & Trucks
Mitsubishi wall unit srk50zg condenser src50zg air con not heating new install
Double check your wiring .if the indoor fan is not blowing then you either have an electrical issue OR bad blower motor .
May 24, 2017 | Refrigerators
Dometic Rooftop RV Air Conditioner Logo
148 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
