Question about Amana NDE2330AY Electric Dryer
How do you take apart the dryer?
It was making a squeaking noise and now it does not want to spin but runs and heats up! What could it be?
  • 10,319 Answers
The belt that turns the drum contantly has broken off. The belt and tensioners pulley will need to be replaced. Sears sells these as a kit at there service centers
Posted on Jul 10, 2010
The dryer is having trouble spinning and is making loud screeching noises. I took it apart and the belt is fine, not sure what the problem is. It is heating up, but like I said it does not want to start...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 24, 2011 | Maytag SDE2606A Electric Dryer
My GE electric dreyer, DHDSR46EGWW, is making squeaking noise and a grinding noise. My husband took is apart last night and put back together. When he started it the noises came back and he said it...
It could be the rear bearing or if not it have your honey take it apart again and inspect the rear rollers, if they turn freely then inspect the front bearing assy it is on the the door and if it looks worn down then it is allowing excessive pressure on the rest of the unit .
Apr 01, 2011 | General Electric DHDSR46EGWW Dryer
When I start the dryer it makes a grinding noise. It heats up and spins but I was concerned about the noise.
heatman101
Oct 22, 2010 | Hotpoint Dryers
The dryer Zanussi ZD100 C makes much noise as an old truck. It bumbles and sound like thunder. It heats all right. The blower is ok. I wonder how to take it apart as the back and sides are connected...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 16, 2010 | Zanussi TD4100W Electric Dryer
My dryer is spinning and heating, but is making a knocking noise.
heatman101
Apr 27, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
My maytag dryer was making a loud screeching noise and then stopped spinning or heating
heatman101
dgsghs
Feb 10, 2010 | Maytag LSG7806A Front Load Stacked Washer...
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
Makes squeaking noise after running for about 10 minutes
Replace the dryer drive belt and the dryer tub rollers.
Mar 01, 2017 | Kenmore Dryers
Squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
May 03, 2008 | LG DLE2532W Electric Dryer
Amana NDE2330AY Electric Dryer Logo
151 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
