Question about Dryers
My is70c drier is only blowing cold air, why ??
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 16 Answers
Either you may have a tripped breaker or element out or even a thermo stat
Posted on Apr 19, 2008
99 s40 volvo air con fully replaced but still not blowing cold air
Your compressor may not be engaging, could be activation switch, a relay or the compressor itself if you do not hear it engage when activating A/C.
Dec 22, 2013 | Cars & Trucks
I am having problem with the A/C on my 2000 BMW 323i. I just Changed the Compressor, Drier, Expansion valve. In march I changed all the lines high/low pressure lines and also changed the Drier as well....
The pressure sw. on the dryer maybe weak but the way you explain it I think the sys is low on Freon. The reason for this is you said it did not get that cold. I would add a half can or one to the sys and see if the compressor cycles longer. Hope this helps.
Apr 26, 2017 | 2000 BMW 3 Series
Is70cuk dryer only blowing cold air, all filters are cleaned water emptied
the one shot stat has blown on the heater. remove rear heater cover and two smaller screws holding element to the cover. you will see the two round stats. both must be replaced. part numer is 1703200, aprox £25.
Jul 06, 2011 | Indesit IS70C Electric Dryer
Hey I am haveing a problem with My 2500HD ac system. I have changed The Condensor, evaporator, and the Compressor. I have charged it to the correct levels. It blows cool air, but it doesn't get cold....
Did you change the Receiver/ Drier and the Orfice Tube/ Expansion Valve? The Receiver/ Drier takes moisture out of the system and the Orfice Tube/ Expansion Valve controls the Hot/ Cold air. If that is bad it may not be opening or closing fully which would not let your A/C get as cool as it supposed to.
Jun 25, 2010 | 2005 GMC Sierra 2500HD 4WD
An indesit tumble dryer, only blowing cold air.
Most likely heating element or thermal cut-off is bad, or both.
Sep 14, 2017 | Dryers
TUMBLE DRIER-INDESIT IS70C
hi did u check the hoses from the pump and check the pump for any obstructions.
Feb 14, 2009 | AEG Washing Machines
My Indesit IS70C is only blowing cold air. It was fine this morning. Do we have to remove the silver back to get to the thermostat?
Remove the lower rear panel, there you will see the heater element and thermostats, make sure the heater is o/k, and replace both stats.
Plz rate my solution
Thanks.
Dec 18, 2008 | Dryers
AC problem
is the compressor turning on? when you turn thwe a/c? on,
and also locate the low side line on engine compartment and feel if is cold, if it is, then your blend door system is not working,
the blend door does control the cold and hot air coming to engine.
Jul 01, 2008 | 2000 Jaguar S-Type
Indesit is70c dryer is not heating?
Take off the back plate of the drier to expose heating elements. There you will find two thermo switches, one with a hole in the middle of it. Push something like a pin into this hole until you hear a click. Re assemble back plate and it should work now
Feb 28, 2008 | Dryers
Dryers Logo
51 people viewed this question
Top Dryers Experts
