I have HP Deskjet F4480 printer. Wheneve I try to copy or print ,on the left side of upper corner of front panel a small orange colour dot appears and blinks. On the left lower part of upper control panel of the printer, Capital letter of E appears for black and color,and two arrows appear and blinks pointing to the two rectangular picture(divided into 4 ) All I know is that printer is warning me that this printer is not working.
    Scholar:
  • 103 Answers
Hardware failure
Posted on Jul 12, 2010
Hp 2050 deskjet printer: colours are confused and orange is printing green.
Try checking you color settings on printer and computer. Also, check your ink cartridge and it's date of manufacture. Sometimes old cartridges behave like that.
Nov 02, 2012 | HP Deskjet 2050 All-in-One Printer
Deskjet f4480 prints documents with the letters in shadow
You may need to do an alignment of the print cartridges. 1. Open the HP Solution Center 2. Click on Settings 3. In the Print Settings section, click Printer Toolbox 4.Click Align the Print Cartridges 5. Click Print Page An alignment page will be printed. Placed the alignment sheet with the printed side down on the right front corner of the scanner glass. Press the scan button to complete the alignment.
Jun 09, 2011 | HP F4480 All-In-One Printer
My printer status show offline eventhoungh i'm online.It can copy(photostat) the document but it cannot print.I alrerady change the printer port but it still offline.My printer is HP Deskjet...
Click Start and then go to Printers and Faxes (XP), Printers(Vista), Devices and Printers(Win 7)
1. Right Click on your printer Icon 2. Click Open or See What's Printing 3. Click the option that says Printer on the upper left corner of the window that pops up. 4. Make sure the only thing that is checked under that menu is Set As Default Printer. 5. If Use Printer Offline or Pause Printing has a check mark. Uncheck it.
Try printing again. I hope this helped.
Dec 26, 2010 | HP Deskjet F340 All-In-One Printer
I have a f4480 hp deskjet. How do you reset settings when you refill the ink (black) cartridge? Because even after injecting the ink, I still get the exclamation mark and orange light. And when even...
Some Hp printers, like Epson, require the cartridge to be reset. There is a chip on the cartridge that needs resetting.
This might work;
Place the HP 60 cartridge on a covered surface so that the metal contacts on the cartridge are facing you. Put tape over the top metal contact in the second column from the left-hand side, making sure the other contacts do not get covered. Put the HP 60 cartridge back into the HP printer. Print a test page when prompted. Take the cartridge out of the printer. Leave the tape on the contact that is already covered and also cover the top contact in the column at the far right, making sure no other contact gets covered in the process. Return the cartridge to the printer again. Print a test page. Remove the cartridge from the printer again, remove the tape from the metal contacts, and return the cartridge to the printer. Print the test page and the printer should read the cartridge as full.
Jun 18, 2017 | HP F4480 All-In-One Printer
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
    the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
    May 17, 2010 | HP DeskJet 940c InkJet Printer
    11 blue dots print out down the left hand side of documents
    It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
    Apr 14, 2009 | HP LaserJet 4600dn Color Printer
    Hp deskjet 6540 carriage out of alignment
    Probably a small piece of paper (now black with ink and hard to see) stuck in the extreme corners (probably the left side).
    Jun 21, 2008 | HP DeskJet 6540 InkJet Printer
    79 people viewed this question
    k24674
    jasbo
    jasbo
    Marvin
    Marvin
