Question about KitchenAid KGST307 Gas Kitchen Range
My gas range KGSC308 timer shows F2:E1. I cannot
My gas range KGSC308 timer shows F2:E1. I cannot make it disappear.
  • 15,935 Answers
F2-E1 - Touch Pad (Keypad) Cable Unplugged -
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
It appears your timer/clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!##
Posted on Oct 01, 2010
Hi, I have Kitchenaid gas stove. the control panel shows the error code F2/E1.. What should I do to fix that?
Most of your F2 errors on stoves has to do with a stuck key. Use a hair dryer or a hot dish towel to warm up the keypad to loosen up that stuck key.
Jan 31, 2011 | KitchenAid KGST307 Gas Kitchen Range
I just want to know what E1-F5 means in my self cleaning oven.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#$ER
May 19, 2010 | Stoves 600SiDOm Gas Kitchen Range
The range displays f5 e1 when i try to run cleaning cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&*(
May 12, 2010 | Whirlpool GS460 Gas Kitchen Range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$#$%
Mar 20, 2010 | Whirlpool GS460 Gas Kitchen Range
E1 -F5- .. Locked - displays after cleaning the
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Dec 21, 2009 | Whirlpool GS563LXSS - stainless Steel Gas...
Door will not open after cleaning e1 f5
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.WER@#
Nov 13, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My display is showing E1 F5 and the self cleaning cycle won't start. HELP? this is on the 75004 model
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$R
Jun 10, 2009 | Kenmore 75002 / 75004 Gas Kitchen Range
WP Touchpad does not work.
The error code of F2 and E1 on your gas range is indicating a keypad failure or an Electronic Range Control (ERC) board failure. The ribbon connector on the keypad could be damaged or shorted. One of the buttons could be stuck or shorted on the keypad. There is a good possibility of a failed (ERC) board as well.
I recommend having a service technician come out and diagnose which part failed and repair your range.
Dec 18, 2008 | Whirlpool GS470LEM Gas Kitchen Range
F2:E1 Error - Now Panel Not Working
good day,
hope this link below will solve your problem.
kitchen
Oct 15, 2008 | KitchenAid KGRT607 Gas Kitchen Range
F2:E1
This has happens to us regularly. Today when it happened I unplugged the oven and let the it cool hoping that would help. It didn't. I did that several times over a couple of hours to no avail. When it powers up, there are a sequence of different readings on the screen before the error code comes up. In my final effort, just before the code F2:E1 appeared, and it read PF, I quickly turned on the oven and that interrupted the sequence. It is now working. Lucky. I hope this helps someone.
Apr 03, 2007 | KitchenAid KGRC707 Stainless Steel Gas...
KitchenAid KGST307 Gas Kitchen Range Logo
164 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
