Question about ValuSoft Ubuntu Linux for PC, Mac, Linux
Linux ubuntu9.10 network confiuration
Linux ubundu9.10 network confiuration
  • Prank3r Aug 20, 2010
    Can you be more specific as to what your problem is with the configuration?
  • none Oct 21, 2010
    What problem with network configuration are you having?
  • 105 Answers
The main network configuration file is /etc/network/interfaces
afeter you edit the network configuration file you should write
sudo /etc/init.d/networking restart
Wait some minutes to the network service to restart and it should be working as per your configuration.
Posted on Oct 24, 2010
Lost internet connection linux mint 14
Installing your wireless driver on a Linux distribution is only half the battle.
Once it's installed, you have to configure it.
This means adding the network name, or SSID (service set identifier), and the passkey for your wireless network.
In older versions of Linux, this had to be done with the "iwconfig" command line tools.
Luckily, Linux Mint has incorporated a graphical utility for configuring your Ethernet and wireless adapters.
Open the "Control Center," which will be found under the main program menu on the bottom right of your computer screen.
Click the "Network Connections" icon under the "Internet and Network" section.
Click the "Wireless" tab in the "Network Connections" window.
Click the "Add" button.
Type the name for your wireless network in the "SSID" text box.
Choose one of the options under the "Mode" drop-down list. Most users will choose the "Infrastructure" option.
Click the "Security" tab.
Choose your network's security protocol from the "Security" drop-down list.
Type the key for your wireless network in the "Key" text box.
Click "Apply" to save the changes.
Click the network connection icon in the task bar. It will look like two computers and can be found next to the clock.
Click on the name of your wireless connection to connect to the network.
http://www.linuxmint.com/wiki/index.php/MintWifi - The_network_manager.
Activate a Wi-Fi Card for Linux Mint
Log into Mint as user root. Launch a command shell, either by logging in in text mode or by launching a Terminal window from the graphical desktop.
Type the following command into the shell:
iwconfig
Press "Enter." Make a note of the name chosen by Linux Mint for your Wi-Fi card it will be the only word displayed flush with the left edge of the screen.
iwlist wlan0 scan
Replace "wlan0" with the name of the Wi-Fi card you noted earlier.
Press "Enter."
Mint will display a list of the wireless networks in range that you can potentially join.
iwconfig wlan0 essid library-wireless
Replace "library-wireless" with the name of the network you want to join, from the list generated by the "iwlist" command. Linux Mint will join the network.
At this point you can browse the Web and access the Internet in other ways via the Wi-Fi card on your computer.
http://linux.die.net/man/8/iwlist
http://linux.die.net/man/8/iwconfig
Getting Started with Linux Mint
http://linuxgazette.net/137/lazar.html
Aug 07, 2013 | Computers & Internet
Am using in my laptop linux os, but its not showing wifi connection in my home,
Linux does not usually play nice with wireless routers, it can take up to four to five reboots to access the router. A trick that I usually do to connect to the router is to join an unlisted network, and use your router's name as the unidentified network name. That sometimes works for me.
I hope this helps!
May 05, 2011 | Computers & Internet
How can I send and receive MMS thru my samsung gt-s5233w
text to your network provider they will send you the confiuration set up when you get it through save it to the phone
Jan 31, 2011 | Samsung Star GT-S5233 Cell Phone
I cannot connect to the internet wireless with my msi adaptorafter installing linux on my computer
Linux wont have much in the way of built in drivers.
You have to find the linux compatible drivers for the msi adapter before you can connect to a network
Feb 13, 2010 | Computers & Internet
I can't connect my ativa wireless g usb adapter to actiontec gt701-wg wireless gateway
re-installed the driver then you check your firewall is enable or what is enable then disable then you check your proxy sever disable it then you check the wireless zero confiuration in the manage the computer then you coonect it then you get it
Jan 01, 2009 | Office Depot Ativa Wireless-G USB Network...
PROBLEM IN REDHAT LINUX
Hello there. You need to install the driver from http://support.intel.com/support/network/sb/cs-012904.htm
As a side note, Redhat AS is not really a great choice for beginners to linux, you may find Ubuntu or another new user orientated Distribution, makes a better attempt at hardware detection.
Hope this helps.
Apr 07, 2008 | Computers & Internet
Linux cannot detect my dfe-690txd
please reinstall your card
on the web of linux
Jan 10, 2008 | D-Link DFE-690TXD Network Adapter
Wireless camera installation
It will work surely provided that the confiuration of access point is in mixed mode 802.11b/g.
Dec 07, 2007 | Computers & Internet
Open Questions:
Toshiba Laptop doesn't start up. Black screen [Solved] -Dataalign If you are facing any kind of issues in Toshiba laptops or other products related to Toshiba brand, then you have come to the right place, as this article is an overview of where you can find the right kind of services, required for proper working of the gadgets by any tech savvy person, in particular the ones using Toshiba products. Another beneficial thing about using Toshiba products is its reliable Toshiba Customer Service , which can be reached any time for assistance with guaranteed satisfactory results. Toshiba customer care services are provided by highly efficient and knowledgeable tech support technicians having years of working experience in the field of providing dependable services to the customers of Toshiba. Toshiba support services provided by Dataalign are the best in class for their consistent services and highly advanced way of resolving tech issues faced by the customers. Dataalign tech support team comprises of expert technicians and they make use of high class technology for fixing the issues in Toshiba laptops and other devices as they have proper knowledge of all kind of issues with their perfect resolution. Dataalign technicians can be reached easily anytime from anywhere through the toll free helpline number +1888784-9316. Dataalign assistance providing Toshiba Tech support engineers are selected through a rigorous process of selection which makes them efficient for providing right support in minimum time with high accuracy. Technicians of Dataalign assist the customers in the most polite way with the assurance of providing highly accurate solution for every issue. For the answer of any kind of query related to Dataalign or for help regarding tech issues contact Toshiba support on their toll free helpline number.
Jun 21, 2018 | Toshiba Computers & Internet
See all ValuSoft Ubuntu Linux for PC, Mac, Linux Questions
ValuSoft Ubuntu Linux for PC, Mac, Linux  Logo
63 people viewed this question
Top ValuSoft Computers & Internet Experts
Mike
k24674
Edwin
Are you a ValuSoft Computer and Internet Expert? Answer questions, earn points and help others
