Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio Washer always Unbalanced (Model WTW6300SW0)
My washer worked ok for the first couple of years. Although, my wife complains that is does not clean as well as our previous 14 year old machine which we gave away in working condition unfortunately.
For the last couple of months it will not wash a load without going into an Unbalanced condition, with loud banging, multiple times. Re-arranging the items does not help. It makes no difference if the washer has a small or large load.
There is liquid in the top ring that can be heard sloshing around when the ring is spun.
It is not a User Problem as we have been able to competently operate it for a couple of years.
I have raised the cover, and except for significant rust on the frame, all looks normal with the suspension.
The washer also leaks although all the hose fittings are secure.
Is a repair manual available on-line?
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
SOURCE: Water Leak
is the pump gray or white? if it is gray then replace it.look where the pump mounts to the ,otor and see if there is a black line coming from the middle.this is probably where your leak is.
just change the pump.
Posted on Nov 05, 2008
  • 141 Answers
SOURCE: should we buy a cabrio?
Its recommended to buy whirlpool washing machine they are having the spares for their old model also when compared other brands
Posted on May 06, 2010
TheMobilian
  • 8220 Answers
SOURCE: Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
Posted on May 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Cabrio top loading washing machine:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
My washer always gets unbalanced load with 7 minutes remaining.
This sounds like a problem with an unbalanced washer or unbalanced load. Your washer has four leveling rubber screws underneath. To keep it from rocking make sure all four points are touching the floor at all times. Washer machine being level is a great plus. Also it could be the amount of clothes put into the washer. The more clothes you put in the less chance of your load being uneven.
Jun 06, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Ld error code model wtw6300sw0
Water level is not dropping while the pump is running. So you must have something blocking the pump. See page 65
May 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
WTW6400 Every time it goes to the spin cycle it is unbalanced and shuts down.Ive checked for level and proper loading.Any ideas?
Mine does the same thing every time. It knocks and bangs and scares the dog as well as guests. Sometimes it fixes itself and sometimes not. Seems to me that there is something in the suspension that has weakened over time. Have not seen anything written about that though. Possibly the liquid in the balance ring is obstructed from moving around properly to act as a counter balance. Our floor is concrete and the machine is level. As we could operate the machine competently for a couple of years, it's doubtful that the problem is operator error!
For a couple of years it worked fine. Well, it functioned but my wife has complained from the beginning that it does not get clothes as clean as our old inefficient machine which we gave away in working order but would like to now have back. One corner of the porcelain turned yellow from the bleach fumes. The frame under the cover is rusty. When the machine goes into UL mode, it leaks.
Initially we had a problem with it ruining clothing in every load following a load of whites with bleach. It saves a few drops of bleach to deposit on our colored king bed sheets and some nice shirts. A new valve replaced under warranty remedied the problem, although it is not clear why it did so. The Whirlpool factory tech reversed the hot and cold water supply hoses. We had a couple of cold showers until I figured out what he had done.
Our whirlpool microwave quit after 5 years. We were told it needed 2 new circuit boards which cost more than the unit did when we purchased it.
I have always tried to buy American, as hard as it is. Our next appliances are going to be from Japan or Germany and not Whirlpool.
Jul 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Piece behind start button broke and washer won't run.
Bonjour, le probleme et tres grave vous avez sappelle CRTL et FN
Feb 17, 2010 | Washing Machines
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Whirlpool WTW6200 Cabrio. We had this washer a little over a year, and have a problem with it getting unbalanced giving either a UL or F1 code, and often dumping water on the floor when this happens. I...
Hi there.
Sorry to hear this. Some washers are notorious for this. I would buy a different brand next time.
Untill something breaks - try loading the machine with a couple of towels when doing sheets - aiming to keep the drum 70% full when loaded.
It's often when there's only 1/2 load that things get unbalanced.
Hope this helps.
Richie.
Jun 14, 2008 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
473 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
