Question about AEG Washing Machines
Aeg Lavamat 64840 programme stops at 1 minute to go. turning the machine off doesn't help and you can't open the door
    Sniper:
  • 174 Answers
The main PCB, before sending the door aperture signals, checks for the following conditions:
• The drum must be stationary (no signal from the tachymetric generator)
• The water level must not be higher than the lower edge of the door
• The temperature of the water must not be higher than 40º C.
Automatic release device
In the event of a power failure, or if the appliance is switched off using the ON/OFF switch, or if there is a
fault in the solenoid valve, the bi-metal PTC cools within a period of between 55 seconds and about 4
minutes (at a temperature of 65°C), thus releasing the door.
if after swiching off for longer than 5mins and the door lock does not unlock the lock must be faulty.
Posted on Jul 16, 2010
Washing Machine AEG Lavamat L64850 - cant change the washing time?
Not all of the options on the AEG Lavamat L64850 are available with every cycle. The Time-savings option isn't compatible with the 40-60 Mix program. See ManualsLib, https://www.manualslib.com/manual/555025/Aeg-Lavamat-L64850l-7kg.html?page=16#manual , for the various washing programmes and the available options.
You can get the full manual for your washer at AEG, https://www.aeg.co.uk/support/download-manuals/ . There are several models listed. The direct link to the manual for the L64850L/91452556002 is currently http://www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL=2013\132\950431EN.pdf .
I hope this helps.
Jun 14, 2018 | AEG Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Why is the wash stopped within a minute or two from starting?
most common problem is a water valve, as long as you have the tap turned on, many people have forgotten to turn it on
Oct 24, 2017 | AEG Washing Machines
AEG Lavamat W1450 Electronic - after about 10 mins of programme machine is making beeping sound and stopping
this is an errorcode !
try to download a servicemanual,
then you can figure out the exact failure -
like : does not heat up etc. ....
May 05, 2012 | AEG Lavamat W1450 Front Load Washer
G'day to you. We have an AEG OKO lavamat 88840 update washing machine. Today we put it onto a 40 deg programme, using the Time Saver function. After approx. 5 minutes, it stopped mid-programme, with...
Check your pressure sensor. Make sure that the air column that operates the pressure sensor is not blocked. Find the pressure sensor and remove the air hose to it. Blowing into it with the hose attached to the pressure sensor will check the pressure sensor. Use an ohm meter to measure if it changes. Blowing on it with it connected to the air column will check that nothing is blocking it.
Nov 08, 2017 | AEG Washing Machines
Aeg lavamat 64840 keeps draining even when it is empty so no programmes will work We have checked the pump and done all the checks in the manual. It drains water out but then doesn't stop trying to pump...
There are variables but the quickest check with minimum equiptment, i would locate the pressure switch then pull the small clear pipe off that is attatched to it. Firstly , blow into the pipe and see if it isnt possibly blocked.(If it is blocked, the control will see the system as over full and all that will happen is the pump will continue to activate). Before you put the pipe back on the pressure switch, activate the washer for a few seconds and see if the cycle wants to start normally. If so, switch off and reattatch the pipe and do a wash test.
May 23, 2010 | Washing Machines
AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
Oct 19, 2009 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
Feb 15, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Open Questions:
Washing Machines Logo
1,008 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
