Question about Tomtom One IQ Routes GPS Receiver
My husbands tomtom IQ routes edition has just frozen - it shows a picture of a world. What can he do to get it back to normal?
    President:
  • 1,561 Answers
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Posted on Jul 10, 2010
I think my tom tom has frozen after drum noise black and white screen writing
I had 1 done the same I had to reset tom tom this was an early edition were u can reset it with a pin
Dec 01, 2015 | Tomtom XL IQ Routes GPS Receiver
How to update my GPS TOMTOM XL IQ routes?
Plug it into your computer's USB port and go to TomTom's website.
Dec 09, 2014 | Tomtom One XL GPS Receiver
Red cross flashing on screen
This means the application has not loaded or it has an issue with the application. Download the full instructions from tomtom website to reinstall you tomtom with fresh application and program etc. YOU MUST back up your device first and ensure you have a copya of the map as you cannot download this. make a backup first and use tomtom home program to install the new application, copy your map back to the device etc. the instructions from tomtom are pretty straightforward to follow. Also contacting tomtom support will get you help in reinstalling the application.
Sep 30, 2013 | Tomtom One IQ Routes GPS Receiver
Can you tell me where is the reset button on tom tom 1 IQ
I'm a little confused about which unit you have, but the answer is simple enough..... If there isn't a small hole on the bottom of the GPS, then simply hold the on/off button for approximately 15 seconds -- until the unit restarts. The small "hole" that I'm referring to will be in the same vicinity as the connector that the cable plugs into. It should say reset right by it, if the reset button is there. If you do have a reset button on the bottom of the device, you'll need to use something to press the button. A paper clip straightened out a bit works perfectly.
The following lists are from Tom Tom's website. I hope this helps:
Devices that are reset by holding the On/Off button ico_open.gif
(GO x50, Blue&Me TomTom, GO x40,
XL IQ Routes, XL,
ONE IQ Routes,
Rider Pro, Urban Rider)
(GO x30, GO x20, GO x10, GO,
XL IQ Routes ², ONE XL,
ONE 3rd Edition, ONE 2nd Edition, ONE 1st Edition
TOYOTA, ECLIPSE, DAIHATSU, ECLIPSE II,
Toyota Aygo Connect Multimedia,
Start ², Start
RIDER 2nd, RIDER 1st)
Apr 29, 2011 | Tomtom ONE 3rd Edition GPS
I have tried to connect my tomtom to my apple computer and some of the downloads failed as it said the device wasn't connected. Know the tomtom has frozen with the 'tomtom' screen and logo. you can...
It seems that some versions of the Apple OS are a problem. I had this issue with my tomtom. I managed to solve it, eventually, and only by a chance remark, by connecting to an older Mac. Avoid OS X 10.6.5 and 10.6.6 (at least).
TomTom support got their in the end - but only after about 5 weeks!
Dec 18, 2010 | Tomtom XL IQ Routes GPS Receiver
Lost the user manual for Tomtom White Pearl Edition so I need a replacement user manual or downloadable version. I believe it is similar to Tomtom One IQ
Hello :
Check for the manual here please : One IQ Routes GPS Receiver manual .
NOTE : Some websites hide the content if you came to the from certain websites , so in this case you need to look for the manual by yourself on that website . I just have found it there .
best regards .
please don't forget to rate !
Apr 07, 2010 | Tomtom One IQ Routes GPS Receiver
Hi guys tom tom xl IQ routes edition via tomtom
Thanks returned item to store Happy New Year to you all and thanks once again Ian Dempster
Jan 01, 2010 | Tomtom ONE GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom One IQ Routes GPS Receiver Logo
573 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
