Question about Honda Garden
Older Honda lawnmower wont start-has gas and fuel
Older Honda assisted push lawnmower wont start-has gas and fuel line is open Has not been started in a couple of years.
  • whart847 Jul 10, 2010
    Helpful but I will comment later if I can get the lawnmower started and running properly
  • Honda Master
  • 6,826 Answers
If it hasn't been started for a couple of years, then the carb could be stuck. Try putting a small amount of gasoline into the cylinder after removing the spark plug. Reinstall spark plug and connect spark plug wire, and attempt to start. If it does, then it is a plugged carburetor.
Also, check for spark when pulling the starter rope with a tool designed to show spark between the spark plug wire and ground. Sometimes people use a screwdriver connected to the spark plug wire and distanced about 1/4" away from the engine block or other ground.
Hope this helps.
Posted on Jul 10, 2010
  • 3 more comments
    It will fire up when i put quick start in the carb intake but dies out quickly.
    What do I do if the carburator is plugged
  • Duane Wong
    Duane Wong Jul 10, 2010
    usually on a carburetor that old, I would rebuild it.
    Spraying the carburetor down with cleaner sometimes helps, but
    getting the gum out of the jets can be tough after that amount of time.
    And what is involved in rebuilding it. Do i need to bring to a repair shop?
  • Duane Wong
    I would take it to a repair shop to have it done if you feel uncomfortable working with gasoline
    and small plastic and metal parts.
    It involves changing the float (plastic), adjusting it, and replacing the jets, and using an air compressor to blow out the orifices.
    Cleanliness is paramount, since any grit or dirt left behind can mean the carburetor won't function correctly.
    Good luck on his repair.
Can u send me the Honda gcv 160 cc and 21 lawnmower engine start video step by step in my mail id
1 - make sure ignition switch is on
2 - make sure that gas switch to motor is in "on" position
3 - Set choke to start position
4 - fill with gas
5 - Pull on starter till starts then push choke back in.
Jun 10, 2017 | Honda Garden
Lawnmower wont start after running then stopped for short period
It should be. The fuel line is under the tank and runs to the carburetor. Make sure you use the fuel shut off, if you have one, or drain gas before you play with the line. Once you find the line disconnect it from the carb and drain any remaining fuel. Then clean with a pipe cleaner and reattach. That should help.
Apr 17, 2013 | Craftsman 190cc 22" Rear Drive...
Toto lawn mower wont start
Hi, do it have a spark plug
Sep 23, 2012 | Garden
Lawnmower starts and dies... where is the main jet for the carb?
try cleaning the air filter, then a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season.
Aug 27, 2010 | Poulan "Poulan" Push Mower
Draper petrol lawnmower wont start
Check the fuel...most often stale fuel creates havoc...YOU MUST FLUSH THE TANK donot add to old crumby gas, YOU MUST clean out the carb(remove the fuel bowl and carb spray all the tiny openings,orifices, check the air filter, check the oil, Add NEW fresh fuel, and hit with a quick spray of starting fluid just prior to restarting...should run out well.
Jul 24, 2010 | Garden
Honda 4 cycle cult wont start. New gas primer primes new spark plug. Won't fire.
Check the start switch and the start switch line. If not broken, check the choke switch and try different settings to start it. Last check the gas line for any cracks. This tiller can be easily be flooded when pushing the prime button..
Jun 25, 2010 | Honda 25cc 4-cycle Mini Tiller
I can't start my honda lawnmower, checked the oil, put new gas use choke,it gives litle sound but not enough to start
Try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline. most lawnmowers have no mixture adjustments, so it is a matter of cleaning the carb, tank, gas lines. Some oils in gas mix systems settle and clog after less than one season. Spark can be tested by sight, remove the plug and use a clip-on ground wire from spark plug body to metal on the engine with the plug wire connected.
Jun 10, 2010 | Honda Gxv160 55hp 55 Hp 25mm Dia Lawn...
Honda gas powered lawn mower will not start
If it sat for years then its likely a fuel problem. Verify this by spraying a prime in the carb and trying to start it. If the unit starts then its a fuel problem. I would drain the tank and replace with fresh fuel, remove the carb and clean it.
Dec 30, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman lawnmower 6.75 horse Eager-1 21''rear drive
Buy a can of engine starter (ether). Prime engine, spray a little ether into the carburator (air filter) and pull start.Works great.
Mar 23, 2008 | Video Game Consoles & Games
Garden Logo
176 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
