Question about Sony PlayStation 2 Slimline Console
PS2 (fatty Model) Does not power on
PS2 (fatty Model) Simply stopped switching/powering on. Does not power on when plugged in even at dealers. No Power cord fuse on plug. Local SONY dealers say that since item is no longer under warranty they cannot replace unit. However they can offer a 50% rebate (approx. €70) off a PS2 slim model since and as long as warranty seal is still intact. If we try to get it opened and fixed anywhere else, the deal is no longer available. Slim unit will have a warranty period of 12 mths compared to teh standard legal 24 mth period!!!
Any idea what could have gone wrong and if it could be worth it to try risking fixing it? Once warranty seal is broken/damaged the rebate-replacement deal is off. Could it be the internal power supply unit or is there a power fuse before the psu that could have blown up perhaps?
any ideas welcome. thks
ms
MALTA
    Sergeant:
    Champion:
  • 427 Answers
No! absolutely do NOT open the PS2. You will make a huge mistake especially since you dont know what to look for. Besided, if someone here tells you it is one thing, how do they know for sure? Just go with the Warranty.
Posted on Apr 19, 2008
My PS2 wont turn on
is either the power cord plugged in all the way in back of the system, or is the switch on the back turned to on. This may work for ps2 non slim.
Jun 10, 2013 | Sony PlayStation 2 (PS2) Console
No power to console. Played one night all okay turned on next day and nnothing happened, no green light or anything
Hi Lisa.
There are a number of things that could cause this, but we know its a power issue so the possibilities are...
Note: Since we know this is a power fault be extremely careful around electical wires and plug sockets
1. First make sure its not the socket and try plugging in the console somewhere different. And check all the connections on the power lead.
2. The fuse at the could have blown (I would check this first) however this is most likely not the case if the power pack (the big black box thing in the middle of the power cable is warm as this means power is getting through.
3. If you know a friend with a PS2 try using their power cable to establish wether or not yours is faulty, if it works simply buy a new cable.
4. If all the above fail, the problem is internal in the PS2 and you will have to take it to a qualified repair person.
If the fuse is blown it will need replacing make sure you get the right amp fuse and simply replace. You can
Jun 16, 2011 | Sony PlayStation 2 (PS2) Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
The on/off switch won't turn on. i have power on (red light) switch clicks but no green light. i have taken lid off and white button seams on work but still no green light. i have even held down little...
This is one of three things. Unfortunately, it's difficult to determine which, unless you start replacing parts.
1. Bad switch. The switch doesn't usually go bad by itself, has the PS2 been dropped? Bumped? Anyone push the switch too hard? It's held in by solder on all 4 corners. If the solder becomes dislodged, the switch can fail.
2. Bad cable. This is rare unless someone opened the PS2 and removed/installed the cable a few times and frayed the internal wires.
3. Bad motherboard. Sometimes a power problem can develop, or the motherboard can short out. It's pretty rare, but I have seen it happen.
4. Bad AC adapter. Recent power surge? It's possible that the AC adapter is delivering enough voltage to power the standby light, but not enough to power the actual system on. You can easily check this by plugged your PS2 up on someone else's AC adapter or taking your AC adapter to someone else's PS2.
You can find parts at the following page:
http://store.richspsxparts.com/ve12s.html
Nov 09, 2009 | Sony PlayStation 2 Slimline Console
When i plug in my ps2 ac cord it doesnt work and i have to push it down for the red light to come and its not the cord coz i got a new one
Quite often the power plug/socket/jack in the back of the PS2 slim console (YELLOW), Can become loose on the main board, or cracked, or simply internaly slack.
This will cause no power or intermittant power.
A loose one can be fixed by re-soldering and a cracked or slack oe needs to be replaced an exellent, Free, simple, 6 step guide for this job can be downloaded in PDF from
http://www.4shared.com/file/147985790/765fc3d0/PS2_SLIM_PDF.html
Spare Jacks/connectors can be found online but the cheapest source is ebay and one of the cheapest there is
http://shop.ebay.co.uk/flettech/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p4340
Hope this helps!
Oct 25, 2009 | Sony PlayStation 2 (PS2) Console
AP5201 KVM was working; after power down, moving rack, setting up again -- no keyboard action. Got the right plugs in the right ports. Powered down as the manual says and powered back up. Tried different...
If other keyboards and mice won't work, it sounds like your KVM bought the farm. Does it have any power lights that come on? is it plugged into a live outlet? Are they PS2 ports or USB? PS2 ports don't like power surges. Is the device plugged into a UPS? Does the UPS have power or is is tripped? In a server room?
Aug 22, 2009 | APC RackMount (AP5201) (DHAP5201) 8-port...
I cant plug in my ps2 to my tv!!
Soi didnt exactly fix this but basically i figured out that the ps2 is simply too old for that new tv. when i plugged in a newer system it worked just fine so i guess ill just have to deal.
Dec 13, 2008 | Panasonic PT-43LC14 43" Rear Projection...
PS2 Slim wont turn on
You might try a friends ps2 power supply of the same type to make shure it isnt the ps2 that is broken. If the friends power supply works, get a working one from ebay or something.
Dec 26, 2007 | Sony PlayStation 2 Slimline Console
Ps2 not working
He forgot to plug up the power cord inside.
Nov 18, 2007 | Sony PlayStation 2 (PS2) Console
Power failure after connecting the mouse
Hi sambi,
If you are currently, working on PS2 mouse port which is the error occurred as stated in your problem. Try to used other PS2 mouse which working on the other pc maybe there was a short circuit on your old mouse. If the problem persist, You can use the alternative way by using USB port to plug your optical mouse.
Try to look for ps2 to usb port converter in the computer stores maybe you can still used your old mouse.
Hope this will be helpful to you.
Best Regards,
Philip
Oct 24, 2007 | Computers & Internet
Sony PlayStation 2 Slimline Console Logo
238 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
