Question about Amana ARB2217CSR Bottom Freezer Refrigerator
Ice builds up in freezer compartment, and I have to manually defrost it about every two weeks. This is a recent problem, probably in the last few months. What do I need to do?
  • blisspeg Jul 10, 2010
    Solution was helpful. I need to have a repair person come and fix it.
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. The problem is one of two things the defrost timer has stoped working for one and not putting the machine into defrost or the defrost heating element has gone bad. Either way these are not really for the do it yourself types as you have to take the inside of the refrigerator apart to get to either one in order to repair or replace.
Posted on Jul 10, 2010
Problem, fridge over a period of a few weeks or less goes from really cold to not so cold with ice buildup on the ceiling of the fridge section beneath the freezer compartment which itself does not ke
Hi, This will happen if you have a faulty defrost timer or the the heater is not working when it goes into defrost. The reason its not so cold after a week or so because the ice builds up & doesnt run efficently which is why when you switch it off & defrost it works great.
Nov 23, 2014 | Refrigerators
Roper RT14 series - Ice build-up in freezer compartment
You are having an automatic defrost problem. there are 3 components in that system and it could be any one of the 3 .
There the timer (most common) heater, and the bi metal terminator the heater and bi metal can be tested with an ohm meter and the timer if mechanical can be rotated into a defrost
Mar 23, 2014 | Roper Refrigerators
Siemens KG39NA00GB fridge freezer auto-defrost problem.
When you defrosted manually, did you get a lerge amount of water down the back of the unit? If not. the drain is blocked. Also clean and clear the condenser
Apr 24, 2012 | Refrigerators
I have a Frigidaire A Rated Frost free fridge freezer Model FRC150FF 13 months old. I have noticed a build up of ice under the bottom drawer of the freezer compartment in the last few weeks. It is easy...
there is a chance that the drain hole in the back of the freezer is plugged or block and needs to be clean when the unit is defrosting the water is dripping in the cabinet instead of out the drain.
Feb 27, 2011 | Frigidaire Freezers
The right side of the fridge is not cooling well. the freezer is fine, but it also making a strange noise
Hi and welcome to FixYa, I am Kelly.
That strange noise your hearing is probably the fan blades of the evaporator fan striking ice build up on the evaportor coils. This symptom is typical of and automadefrosting problem.... or someone left the freezer door open for a very long period.
You can try doing a manual defrost by unplugging the unit and place a fan blowing into the freezer compartment / compartment making noise for about 2 hours. (makes a water mess) After 2 hours tend to the water mess and restart the unit. Most likely the noise you heard will be gone... for a few days. If you have an automatic defrost problem the noise will return in about 72 hours as the ice build up gets larger on the evaporator coils.
Depending on date of manufacture this unit can have either a manual defrost timer or an adaptive defrost control board that controls the automatic defrost. .
Thanks for choosing FixYa,
Kelly
Nov 26, 2010 | Samsung RS2630SH Side by Side Refrigerator
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
Freezer builds up frost and ice too quickly.
Either the door gasket is not sealing well or the unit is low in refrigerant.
Sep 24, 2009 | Freezers
Loud fan - ice build up in fan compartment.
Check resistance on bi metal thermostat/heating element.Make sure continuity is present on thermostat before defrosting.Advance derost timer if analog unit.
Sep 05, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Freezer cold. Refrigerator very warmer.
Hi there. This should be a self defrosting unit. Check the defrost clock. It's usually behind the grill at bottom front of frig. or near the compressor. There is probably a little window on the clock motor where you can see it turn. You can manually advance the clock to put the unit into defrost mode. Check the defrost heating element. This is the usual problem. It is under shrouds where all the frost builds up. If element good, check defrost thermostat connected to element mechanically and in series electrically.
Thanks
Paul
Jul 12, 2009 | Kenmore 61042 Top Freezer Refrigerator
Ice builds up on evaporator coils. After chipping off the ice, refrigerator is cold again. This lasts only a few weeks as ice builds up. Eventually, the freezer is cold but the refrigerator is very warmer....
Assuming this was originally a frost-free model, either the defrost cycle timer died or the defrost heating element died. If it's the timer, you might be able to manually start and end a defrost cycle every few days. If it's the heating element, you may be stuck with what you're doing or an expensive repair or buying a new refridgerator.
Amana ARB2217CSR Bottom Freezer Refrigerator Logo
29 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
