Question about NetGear DG834G Router
Netgear router unable to find key do not have a disc or copy of no. how can i get the key
  • 61 Answers
Connect by Cat5 cable to router and use ip address of router, normaly 192.168.1.254, in you address bar in IE this will connect you to the router setup screen so if you go to the wireless set you will see the wep key
Posted on Apr 24, 2008
I can't upgrade the firmware on my Netgear WNR834M
Go to the Netgear support WEB site to get a copy of the Resource CD for your model router.
Mar 30, 2012 | NetGear RANGEMAX WNR834M Router...
Tip
How to check wireless security key or passphrase on NETGEAR routers.
Most of the times after configuring the wireless connection on the NETGEAR ROUTERS, the user either forgets the security key or misplaces it.
In order to get this key we need to login to the router's page using any computer which is physically connected to router. The below steps are applicable for most of the NETGEAR routers.
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.1.1' or'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase(or network key).
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Hope the above steps will help the user to locate or reset the wireless security key.
on Feb 10, 2010 | Computers & Internet
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
I want to connect with my Nintendo DS Lite to my NetGear router. But it says i need a WEP-key but i can't find it on my router. Can someone help me?
There are 2 ways to find out the WEP key on your network.
1.
Netgear usualy sets default key which is located underneath the router ( it is a 10 digit long number you find below the bar code )
2.
If you are still unable to locate the key, download this utility program and it will help you locate the key and other key information about the router ( network ) you have setup
Click on the download button below and follow the instructions
Download
* Please rate this solution with thumbs up
Oct 28, 2010 | NetGear WGR614 54Mbps Wireless Router...
Unable to connect to netgear router
is it a wireless computer or the wired computer?
I believe the main computer is online.
Check the settings on the router.
You will need to open the router set up page.
here you will see the settings of the router.
If you are trying to connect to the wireless network then make sure that you are typing the correct network key.
Click here for more information about routers and network
Oct 09, 2010 | NetGear WGR614 Wireless Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
I have no serial number for my netgear wpn824
http://192.168.1.1
or http://192.168.0.1
this is efault acees router.
then it rpompts for usename and password
type userbname "admin"
password :"admin"
or password is blank
then go to advanced security.
u find encryption key read it .
then when u try to connet this the key fopr connect your wfi .
if u not able to connect the router first then u have to reset your router.
for that u have to ptress reset switch for 10 seconds it is in back side of your router.
but pls let me know
Jan 03, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless network
WHATS THE MODEL OF THE NETGEAR ROUTER? you have to have the router address and access the router through internet explorer or firefox. once logged into the router page online then you can change or access the security tab copy or remove the WEP KEY THEN TRY TO ACCESS THE INTERNET WITH THE KEY OR WITHOUT THE KEY YOU DECIDE WHICH WAY TO GO
May 20, 2008 | Acer Aspire 5100 Notebook
NetGear DG834G Router Logo
27 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
