Question about Dometic Rooftop RV Air Conditioner
Duo Therm dripping water in camper when shut off. My Dometic Duo Therm Ducted AC drips quite a bit of water when shut off after running for several hours on hot humid days. The condensate lines are open. The lines drip steadily while the unit runs. When shut off the lines flow a great deal of water, suggesting that the pan is full. At this point I notice water dripping from the duct work. Thank you for your help!
  • Mike Butler
    Mike Butler Jul 10, 2010
    Dripping from all ducts, or just at ceiling assy where filter is?
  • wadesmith Jul 10, 2010
    Dripping from the ceiling assy where the filter is. Water then runs over the ductwork. I see evidence of water spilling out of the rooftop ac unit condensate tray. THe motor coach is parked in garage and not moving. As mentioned before, water spills when shut off. Thanks for your help!
  • Dometic Master
  • 6,674 Answers
Remove the filter at ceiling and run the AC on cool etc, and see if you can feel cool air leaking across to return air inlet where the divider between cold and return is. Check along all edges, etc for any cool air . Careful of wiring, but you should be able to get hand in there and feel especially around the edges where it should be sealed tight. Quite often a leak in that area causes cold air to enter return air and causes excessive condensation. Another thing to check is look way up inside opening for return air, with a flashlight and see if any dirt/dust on coils and fins of evaporator, and if so, needs to be cleaned off with a vacuum, and brush attachment. Let me know what you find.
Posted on Jul 10, 2010
I have a duo therm model 57915 522c1 air unit on my camper. Turned it on and was working fine. Then it shut down. Doing nothing now. Any ideas?
water draining from condensate hole ??? if not its shut off on high water level (you don't want water dripping into your nice camper right ?)
bees are my nemesis on these they love to build mud nests in the drain holes and stop em up !!
Aug 25, 2016 | Heating & Cooling
Duo therm 57915.331 not cooling
make sure fan on auto and on cool if ok bad cooling unit
Jul 05, 2012 | Dometic Rooftop RV Air Conditioner
Water drips into the camper through the foam rubber air intake, after it runs for awhille
Sounds like your drains for drip pan under the evaporator area are plugged. They are located at the base of the AC unit on roof. Look real close under AC unit near front, for a hole in base plate of AC on each side. Water ( condensation ) should be dripping out of those holes pretty steady when running.
You should have an inch or so clearance between base of AC and roof to try and get a bent piece of wire, or similar in to hole and try to clean it out. If that doesn't help you will have to remove plastic cover and remove all the screws that hold the front cover over the evaporator and remove the front metal cover. Look down at base of the coils and fins and you will see a drip pan that has small holes at each end for drainage. They will get plugged up with debris, thus poor, if any drainage. I use a long air nozzle and a small compressor to blow them and the tray out to clean it well. That will usually cure your problem. Please remember to shut all power to AC, off at breaker panel before removing the cover on roof to avoid electrical shock.
Sep 04, 2011 | Dometic 57915531 Air Conditioner
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
My dometic duo-therm freezes up and does not drip water. What is the problem?
Either the unit is low on charge or the fileter/coils are plugged with dirt and decreasing the air flow so that is freezes
heatman101
Mar 26, 2011 | Dometic Rooftop RV Air Conditioner
Water dripping out of rv ac into rv.
Is it a ducted system? If yes, check that there isn't gaps between the divider that separates return air at the front, with forced(cold) air. You can usually use a flashlight and look for gaps, or even (very carefully) feel it blowing cold into the warm air return. If you find some gaps, buy some foil tape, and tape them off good and retry and see if it still happens. Some older units experienced cracks in drip trays that allowed condensation to drip inside as well. Get back to me with year of your RV, and whether it's ducted or non-ducted system, and perhaps I can guide you better on what to look for.
Jun 20, 2010 | Dometic Rooftop RV Air Conditioner
Help, Brand New A/C unit drippin inside camper
they do that its normal operation, you will get varying amount depending on your location and humidity. If it is not balanced or installed right it drips in the camper.
Aug 16, 2009 | Dometic Rooftop RV Air Conditioner
Water dripping inside camper from AC unit
Basically there are holes in the base of the AC that allow water (condensation) to run out, that may be plugged, and usually you can tell by how much run-off you have on your roof, and the stain will also guide you to where to poke with wire to unclog. Best way to be sure is to take all the screws out around base of cover & lift cover off. Just watch for bees, or wasps before you do, they like to nest in there..If all unplugged & running out good but water still coming in trailer, then you may have a cracked drain pan.
Aug 08, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
525 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
