Question about Briggs & Stratton Briggs and Stratton 30338 10000 Watt Briggs Stratton Pro Generator
I,ve got an Briggs and Statton elite 10000 watt generator, it wont supply enough power to the house evrything is dim lights etc, Ive used it amny times before it will pretty much run the whole house however now the voltage is very low. I checked the voltage coming off the plug I'm only getting 80 volts both terminals. I tried switching the reset circuit breaker with another on the machine same results. It popped once before but we just reset it. Any ideas?
  • 6,674 Answers
Does it appear to be running as fast as it always did, as in RPM's are same as usual? If there is a fuel problem and rpm's decrease due to that, voltage will drop as well. Other causes may be internal problems with generator circuits etc, and will need technician to troubleshoot it properly.
You can try increasing the throttle manually and see if voltage comes up.
Posted on Jul 10, 2010
We have a Briggs & Stratton Elite Series 5500 watt 8200 starting watt generator, it locked up on us last winter & we can't find out why, what can we do
If the engine is locked, it could be any one of several things. Most are rather expensive, like: seized due to no oil; broken rod; bad valve, etc. An engine mechanic is going to have to troubleshoot it for you.
Oct 09, 2016 | Briggs & Stratton Electrical Supplies
Briggs 6200 elite generator. Starts runs good no ac output and display is blank
http://www.ebay.com/itm/BRIGGS-STRATTON-GENERATOR-OPERATORS-MANUAL-ELITE-SERIES-6200-RUNNING-WATTS-/401042177246 $14.95
May 30, 2016 | Briggs Electrical Supplies
If I have a danbury portable air conditioner that uses around 7 amps to run, how big of a generator do I need to run it, ( ex. 2000 watt, 3000 watt, etc.) Thank you!
5,500 watts should do it because you need to consider the starting watts of your air conditioner and not the running watts, but if you want to run some other things you might as well buy an 7,000 watt genarator because the price isn't that much more depending on the brand.
I have a Briggs and Stratton 8,500 starting watts. I live in SouthEast Florida and I use it whenever we have a hurricane. I have it hooked to a transfer switch and it works everything except for my electric range and my three ton air conditioner. It will also work my hot water heater, lights, fans etc. I have only used it one time and it works great.
I plan to buy a whole house generator with the capicity of 25,000 watts so if you know anyone that could use it (even in it's original box stored in my garage, no rust or ware and starts on the first or secong pull) and they are in or near Boynton Beach, Florida then perhaps we could make a deal.
wa2yyx@juno.com
Good luck,
Marty
Jul 17, 2014 | Electrical Supplies
Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
Engine is blown what size brigsss &statton engine doi need
From what I can tell you have a model #212400 engine. Look for the model and spec numbers on the engine. They are usually either stamped into the top of the rocker cover near the spark plug, or sometimes on the housing that the recoil starter bolts to. You will need the spec number when you order an engine to make sure you get the correct one for that generator. I found all the information at this link which includes owners and parts manuals which may be helpful to you.
http://www.briggsandstratton.com/generators-pressure-washers/support/operators-manuals/?NTT=30242
Jul 19, 2011 | Briggs & Stratton 6200 Watt Electric Start...
The computer has on occasion crashed for no apprent reason. I had the power supply out and it has normal light indications until it i plugged into the mother board. I have had itwork normally, for a...
Bad Power Supply. Weak voltage power rail.
Bestec is a low quality power supply. Used to save the computer manufacturer money.
Also, a Power Supply with a weak voltage power rail will put out enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on, and/or keep it on.
A) ALL the LED lights use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
Replace the Power Supply. Clean the inside of the computer out, with a can of compressed air for computers before installing.
What is the computer manufacturer name, and Model Number. The Model Number is on the back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Dec 04, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
I have a bsv800 that is only putting out 2.5 vac on each side. I checked the continuity (sp) and each side shows .001 res. I've tried to field flash using a drill and a light set wired in series and still...
If the Stator continuety and ground checks are OK, as you say. Then the problem is in the rotor. you need to check the exitation supply. The voltage regulator. This should be a dc supply. Check if you have any. If not induce a supply, ie battery etc. and while induced supply is on, check output voltage. If this is now reasonable you have proven a voltage regulation problem. Then investigate regulator further.
Mar 29, 2010 | Briggs & Stratton 8,000 Watt 16 Hp...
I recently purchased a Husky 3750 watt generator to ''hook-up'' to my house. The wiring already exists so I figured I would just plug and be good. NOPE! I get it started with ease but when I try to...
Is the house dead??? Did you turn off the main breaker in the house?? It sounds like you are sending voltage to the generator.Do you have a switch that stops the power from going down the street from your generator?? 3700 watts is not a whole house genny, you need more like 6500. 5000 min, unless you are just running the fridge and the lights. Is your "plug" wired into the fusebox through a breaker or straight to the bars? You gotta check these things out.
Feb 26, 2010 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Briggs and Stratton 30338 10000 Watt Briggs  Stratton Pro Generator Logo
276 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
