Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Vk8105r only passes small flow of gas on start up in brivis c.h.unit. Incomeing pressure is 2.75kpa which i have checked, how do i adjust flow rate on this valve.
2 Suggested Answers
shastalaker7
  • 1515 Answers
SOURCE: Gas Furnace Will not light
Hi, normally when you turn the gas off at the flex line valve and leave it off for awhile, the gas has to clear the gas valve and lines up to the pilot. Purge its self of air before it will light again. It will take the electronic ignition several clicks and more before there is enough gas to light the pilot and then open the main gas valve to fire the burners. Tell me, what kind of gas furnace is this when you speak of water? you say the site glass was full and you had to drain it and then the ignitor kept on clicking when it normally only took one click to light it. Please let me know the style as in a split system, a package unit, all in one, or what you have. I will wait to hear back from you. If the pilot does not light right away, then yes let it continue to click and see if it will light. On a heater with the electronic ignition control module on it or a circuit board, this is what tells the pilot coil to energize to light the pilot. It will send power to the pilot coil to open and let gas through to light and same for the main gas valve, will get a signal to open when the pilot is on. It will not open unless the pilot is lite for saftey. I will wait for you're responce.
Shastalaker7
Posted on Jan 18, 2010
I have a Brivis Buffalo 85, pilot light is on main burners will not ignite when turned on? It seems like gas isnt allowed to bar which turns on main burners
Usually a thermocouple or similar device is employed to allow fuel to flow once the unit sees that there is sufficient heat to ignite the fuel. Otherwise it can be a fuel valve that "sees" an unusual flow of gas which sets off the safety.
May 07, 2014 | Honeywell Programmable Thermostat Heater
I have a Troy Built GVC 160 (2600 psi) pressure washer. I used yesterday afternoon without problem. Today, I can get it started, but it conks out immediately as soon as I engage the wand. I'd...
Make sure that the engine is set to full power. Lower the pressure to the unit with the pressure adjust knob as much as possible. Check the nozzle to make sure that no debris has entered and is lodged at the tip of the wand. Start the engine with the spray gun handle in the open /on position allowing water to flow thru. Allow the engine to run for a while to warm-up. Increase the pressure a small amount at a time to reach the desired pressure. To increase the life of the unit, do not use the machine at max. pressure setting. Adjust to about 75% of rated capacity and increase only for stubborn debris then reduce. Good luck
May 27, 2011 | Garden
How can I adjust the flame on the simmer burner to be lower? It seems to be too much flame for a simmer. Otherwise cook top is working great.
Where the gas comes into the stove, there is a regulator. Have a service person check the incomeing gas pressure after the regulator with a manometer. Sounds like you are getting too much gas pressure to the range.
heatman101
May 23, 2011 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
Press washer starts an runs for 5 min then shuts down/ restarts in a few min then shuts down again
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. The high-speed exhaust air must pass freely.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas, and then put in new gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Check small engine repair shop or auto parts store for gum out, and don't store engine with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way on the spark plug?
Oct 14, 2010 | Craftsman Garden
Hi We have just arrived back in Wellington from overseas. Our house has a gas central heating system - the unit is Brivis Buffalo 20. What we would like to know is how cost effective the Brivis Buffalo 20...
Hi, if you are planning to change this system out, please stay with a gas fired central system as compared to a heat pump, they are much more cost effective. Heat-pumps have so many problems as there are more parts on them to go wrong. The compressor and condenser fan motor run year around as with a heat-pump they use what is called a reversing valve that changes the flow of freon making the indoor coil the outdoor coil and the same with the outdoor coil becomes the indoor coil in the winter season. I can recommend excellent gas fired units compared to the Brivis unit you have that is much more cost effective, such as the Bryant, Carrier, Goodman. I would go with a Bryant and talk to a dealer. Stay away from a heat-pump no matter what they tell you as I have worked on them for many years and if you have gas available, stay with gas. You will heat your home much faster and save on electricity as this heat -pump units need heat strips for back up heat as they can't keep up the temperature with out them. I hope I have been of help to you on this, and you will be kind when rating me as I know you will. Please contact a Bryant dealer as you will not regret it.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 05, 2010 | Heating & Cooling
Shut off before it reaches 150 psi turned up the regulator up but it stops about 60 psi should go to 150 psi
the air regulator only regulates the flow of the air as to how much. their is a pressure switch that turns on and off the power to the compressor when it reaches it's set pressure.
follow the plug wire to a small box this should have the switch arm you flip to start it.
remove the cover with the unit un-plug.
there will be a spring with a nut on top tightening this nut or loosening it will adjust when the pump will cut off.
the best way is to test by adjusting one way and watching the pressure till it hits the desired rating you want.
if it keeps pumping un-plug the unit then back off the nut or tighten till you hear a click then plug the unit back in it should not run then.
drain the air and re try the unit it should cut off at the pressure then if so your fixed look for burnt contacts if their black and have little craters on the contacts then that hole switch should be replaced and you can buy them at the presetting you need.
hope this helps
Sep 03, 2010 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need flow rate and pressure adjustment proceedure for an old raypack 266 not electronic.thanks murray
The maximum flow rate for that heater to be installed in without a bypass is 125 GPM. The owner's manual can guide you thru gas pressure adjustments or adjusting the set point of the water pressure switch. Please note that unless you are installing the unit below or significantly above the water line you should not have to adjust the pressure switch. Whenever you do adjust it, be certain to turn the pump on and off several times to be certain the heater reacts to the pump condition...failure to shut down when the pump does can be a serious and dangerous condition.
Dec 15, 2009 | Raypak Millivolt Gas Pool Heater 266,000...
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Starts fine, but will not accelerate: Homelite UT-10798R
Do you have the H and L adjuster screws on the carb? If so, then normally I'd back out a little bit on the L (low speed side of carb) The instructions for adjusting carbs, years ago, on 2-stroke, say to back out on the L when motor will not rapidly rev up. Most 2-stroke carbs have these 2-jets. The L is for gas to pass to motor with butterfly throttle plate closed. When opening throttle plate, there is a sudden rush of air, at first, and this L adjustment is allowing enough gas to pass for motor to begin to rev. up. Then the gas will also flow through another small port H, usually a small brass tube in the venture area (smallest diameter section of carb). You adjust the H with the throttle wide open, motor revved up. Turn either in or out slightly till highest RPMS reached, motor smooth and fast, then turn H out about 1/4 turn. The idea is to run motor slightly rich for highest HP when under load (cutting). Hope this helps
Nov 18, 2008 | Garden
Heating & Cooling Logo
109 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
