Question about NetGear DG834G Router
Connection do not have key for router how can i find out what it is
  • Michael Lake
    Michael Lake May 11, 2010
    Do you mean username and password?
  • 61 Answers
Connect by Cat5 cable to router and use ip address of router, normaly 192.168.1.254, in you address bar in IE this will connect you to the router setup screen so if you go to the wireless set you will see the wep key
Posted on Apr 24, 2008
Netgear Wireless router WNR1000 connect ipad
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 01, 2012 | NetGear WNR1000 Router
Want a wireless connection
First you need to purchase a wireless router of your choice, select a well known brand.
Then connect the wireless router with a LAN cable to configure the router's wireless settings.
Then remove the LAN cable and connect the ADSL model to the wireless router WAN/Internet port with the LAN cable.
Some later model wireless routers have the Password(ie.Encryption key) and the SSID already configured in the wireless router andthis information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adaptersin your computer/laptop.
If these settings do not suit you, then it can be changed to suit yourrequirements.
The encryption key secures your data and wireless connection from unauthorizedaccess.To configure the wireless settings in the router, connect a LAN cablefrom your computer to the wireless router, then open a Browser on your computerand enter the router's configuration IP address, then enter the admin login andpassword and then go to the wireless settings and configure the SSID andEncryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2key.If you use the Passphrase method select either WEP or WPA or WPA2 togenerate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born inJanuary 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop,configure the wireless card in your computer/laptop with the router's wirelesssettings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptopscan communicate with your wireless router.
Apr 25, 2012 | Computers & Internet
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
Forgot the key
Hi friend,
If you forgot the key to connect the router then try connecting the router with the Lan cable and open the router console in the browser by typing "192.168.1.1" and from the router console you can recreate the new key.
If you are not able to connect through the Lan cable then you have to reset the router and re-configure it again.
Thank you.
Dec 08, 2010 | Computers & Internet
I can contect with the Wireless router .. But I
First to check whether Internet is working Connect your computer and Router with Ethernet wire instead of connecting wirelessly. If Internet works on wired mode that means security key for wireless is wrong. Change the SSID (name of your network) from Router login page and then connect again while ensuring you are entering the correct key. As sometimes even if you enter wrong security key Computer will show connected to Router but you will not be able to access anything.
May 25, 2010 | Linksys Wireless-G Broadband Router
I need ssid for network and security key. i have a netgear router.
that's not a question.
you do need ssid to access a router, the ssid identifies the router (it's the name of the router)
you do need a security key to access a router (that's the key to access the router)
if you have neither you're not going to be able to access the router or go online through that router.
please provide details of what your problem is and will try to help.
Dec 26, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
We forgot the WEP key or WPA Key for our Belkin G + MIMO router. What do we do?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 01, 2009 | Belkin (F5D9230-4) Wireless Router...
Need network key for NETGEAR (virgin) to connect
for that you have to access your router.
connect your router to computer with ehternet cable.
then access it with following link.
http://192.168.1.1
or http://192.168.0.1
type user as 'admin' and password as "admin" or blank or 'password'
then go to wireless security then you find WEP or WAP key there but it is in * or # format so you can't know it.
So you have to set new key so you can easily know it.
Then set new network key then save and restart the router then you can connect it with new key.
Aug 22, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Wireless router connection problems
Assuming "cannot connect to linksys router directly" means you cannot connect to a Wireless Lan managed by Linksys router,
1) try to connect new computer to LinkSys Router using a Lan cable, add new PC to your network.
2) recover protocol (WEP or WPA) and Key of WLAN (Passphrase or Key: TKIP or AES) either from other PC on same network either from your Router.
3) If you missed actual key you must connect to router and reset it to a new key to be eventually used for every connected device.
Call for detail on this possibility
Dec 29, 2008 | Linksys Access Point WAP54GP Wireless-G...
Connecting lap top
If this is a new router you will find everything you need in the router's manual. You will need that to set up the WEP key. If the router has been used wirelessly before, then you will need the WEP key to set up the connection through the windows wireless connection wizard. If you don't know the WEP key, you will have to connect to the router with a cat-5 cable and access the router that way with your internet browser to find the WEP key, or generate a new one. You'll need to type in the router's IP address in the address bar of the browser.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 26, 2008 | NetGear DG834G Router
NetGear DG834G Router Logo
21 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
