Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
My lcd model is KLV-40X200A or KLV-40X250A . The standby light flashes 7 times after every 2 sec break second break. Please what could be the problem
My lcd sonyklv-40x200a is problem that picher is good but no dispaly
Posted on Feb 23, 2013
5 Suggested Answers
  • 608 Answers
SOURCE: Hi I have a Sony Bravia KLV-40S200A which wont
I had a similar problem with my 42 Inch Philips 42PLF5432D/37 LCD HD TV. It would turn on but then shut back off after about 10 seconds. Then it wouldn't turn on at all. The problem was a bad capacitor. Several bad capacitors. They are inexpensive and fairly easy to replace if you don't mind digging around in the back of your set and soldering some new ones on your Power Supply Board. Or take the less inexpensive route and look for a whole new Power Supply Board. Good luck. Hope this helps.
Posted on Dec 08, 2010
mistersony
  • 320 Answers
SOURCE: Flashing Standby Light (6 times every 2 second interval)
A 6 flash error indicates a problem with the backlight. Your set is less than a year old and still in warranty, so you should contact Sony and arrange for a service call to get it repaired.
Posted on Nov 10, 2008
  • 1170 Answers
SOURCE: Sony LCD (Model no. KLV-26V300A), standby light
Good day.
Blinks in the indicator signifies malfunction particularly in the horizontal and vertical sections. It is sometimes caused by loose connections due to wear and tear.
If parts would be available, then there would be no such thing as obsolete boards. You can request your technician to have the degree of repair be evaluated first to determine if the expenses would justify its existence.
Your respose is highly appreciated.
Regards,
Arjun
Posted on Jun 13, 2009
yourstupid
  • 4 Answers
SOURCE: the standby button is flashing twice- sony bravia klv-40v550a
Unplug the power cord for 30 min, plug back in and turn on.
Should ths not work seek repair or replacement
Posted on Apr 10, 2010
What causes TV on powering up to go to standby and red standby light flashes 7 times every 2 seconds?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 12, 2015 | Sony KLV-40V300A 40" BRAVIA MultiSystem...
Connection of bravia klv 40 with samsung note 2
yello is usually for video
white left audio
red right audio
but some cables have different config all i know that you could try switching yellow with white and see if works then
Mar 09, 2014 | Sony Klv 40X200A 40X200A Multisystem Flat...
Sony Bravia KLV-40X250A power indicator blinks once but screen is black
um u should turn your tv off for like 10 minutes , i think yourr tv is a internet tv so let it cool sometimes sony internet tvs freeze with black screen so try it out.
good luck :)
Aug 06, 2012 | Televison & Video
Problem with a Sony KLV-26HG2 LCD tv switching on for 2 secs then switching off/ flashing standby light
http://electro-medical.blogspot.com/
Apr 12, 2012 | Sony WEGA KLV-26HG2 26 in. HD-Ready LCD...
I have purchsed (Sony Bravia LCD KLV-32 bx300). when i plug it in The standby indicator then flashes (red) five(5) times then there is a two - three seconds break followed by another five flashes then a...
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also, look for popped capacitors that would make the values lower than need be for the tv to power on properly.
After you repair the power supply's capacitors you may need to replace other components if needed
BUT always start at the root of the problem (power supply) and work your way to other components
Please rate if this helps :)
Mar 08, 2011 | Sony V SERIES BRAVIA KLV32V300 32 in. LCD...
Standby Indicator flashes red 6 times between 2 second intervals
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) five (5) times then there is a two seconds break followed by another six flashes then two seconds break etc. What might have caaused this and what should i do?
Apr 13, 2009 | Sony Televison & Video
My TV (Sony Bravia LCD KLV-32S310A) goes of after 20 seconds when it is switched on. The standby indicator then flashes (red) six (6) times then there is a two seconds break followed by another six flashes...
6 times blink shows problem with back light inverter board.
TV requires back light inverter board replacement. If you have electronics repair experience and want to repair TV by yourself, let me know to guide you part purchase.
Apr 13, 2009 | Sony KV-35S42 35" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
277 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
