Question about Samsung HC-P4363W 43 in. TV/DVD Combo
Samsung tv TXP2734X/XAC How can I raise the lines
Samsung tv TXP2734X/XAC How can I raise the lines at bottom of screen a black stripe is creeping up and bottom lines of caption are hidden. I am hearing impaired and must have captioning. for fun I should tell you this tv turns itsel*** since it was 1 year old. It can do it repeatedly during one episode or not for months in between. Caption is my big problem. thank you for your help I do appreciate it. Cairine
3 Suggested Answers
  • 154 Answers
SOURCE: Samsung 42 flat screen 1080 we can't get rid of closed caption
I'm guessing your Samsung has the same configuration options as mine...
1. Press the menu button on your remote to display the menu.
2. Use the down button (below the enter button) on the remote to scroll down to the "Setup" option.
3. Press the right arrow button then scroll down to "Caption".
4. Press the right arrow button twice, then highlight the off option and press the enter button on your remote.
Posted on Jul 24, 2009
  • 4 Answers
SOURCE: Can't turn caption off
Hi just go to menu and highligth caption off then push OK or Select.
Posted on Aug 08, 2009
I have a Samsung 65 inch curved tv. It has a small black horizontal line. Also a large 4 inch black vertical stripe on the left side of the screen. Do you think a new tcom board would fix the problem?
Try unplugging all the connectors between the TV circuit boards and then plug them back in (be gentle they are fragile), this can often be caused by a poor connection.
Oct 25, 2017 | Samsung Televison & Video
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
There is a vertical black line about 25% of screen.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 28, 2015 | Samsung PN51F5300AF 51" 1080p Plasma TV -...
I have a 52 inch Samsung TV, on the screen have solid, color vertical lines on the right, about 1/8 wide, on the same time the half of screen blink on the right too.
not knowing the model... i will try to help with this common samsung issue, if i can. / unplug the tv, and wait a few minutes to avoid shocks. / remove back panel. you will see several ribbon connectors, (about an 1" to 1 1/2" wide) usually near the bottom. / carefully remove the ribbon (ONE AT A TIME) and clean the contacts GENTLY with a pencil eraser. (DO NOT use chemicals) / reinsert the ribbons and try the tv. // vertical stripes are almost always the result of poor contact between ribbon and socket. / NOTE!. you can do a quick test before opening the set by [carefully!!!!] twisting the screen and watch to see if the vertical stripes change or disappear. / if the stripes change, bet on it being the ribbon contact problem.//// hope this helps, it has worked on a number of TVs.------Jay
Oct 26, 2015 | Samsung Televison & Video
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
White stripe down the samsung 40" flat screen tv
White or black lines or stripes usually indicate a faulty panel. Usually not worth repairing.
Dec 22, 2010 | Samsung LN-T4665F 46 in. LCD Television
Screen will periodically go half black. Then it goes back to normal. Or the black slowly creeps up from bottom of screen.
Ur backlight video board is dying,just not completely dead yet.Must replaced to solved this prob.
Dec 11, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Black stripe down TV plasma screen
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Samsung HC-P4363W 43 in. TV/DVD Combo Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
