Question about iLO 3200 32 in. LCD Television
Our ilo tv will not turn on. we have replaced the
Our ilo tv will not turn on. we have replaced the batteries in the remote, switched the power cord to a different plug in and rebooted- unplugged the tv, h the side power button in for 5 seconds, then plugged power cord in again. The only thing attached to the tv is the direct tv box. The red light bliknks but will not turn green and power the tv on - help! lolot@att.net
  • 11,361 Answers
So hittin the power switch on the TV and all you get is the blink red light. You are going to have to open it up and inspect the inside, start at power supply module.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 11, 2010
How to fix power on problem?
This can be a result of a stuck button on the TV or remote. Remove the the batteries from the remote to prevent a signal from it being sent. Operate all the buttons on the TV one at a time in an attempt to "un-stick" any stuck button(s).
Press the power button on the TV to see if it will turn on. If it does not, check for an open fuse or tripped circuit breaker. Check for the presence of power at the outlet by connecting a table lamp or other electric device. If power is off, see if a wall switch is off somewhere - as it is not uncommon for a switch to control 1/2 of an outlet.
Make sure the power cord is connected at the TV set. Many power cords are completely removable and the end the connects to the TV may have been loosened or fallen out. Visually check the length of the cord to make sure it has not been damaged or cut. Do not use you hand to feel for damage unless the cord has been unplugged from the outlet first.
Unfortunately, if you're unable to turn the TV on; it will probably need to be serviced professionally. There are typically no user serviceable parts inside the TV itself. If your TV has a fuse holder on the outside of the TV, you should unplug the TV and remove the fuse for replacement if found to be open or blown.
Lastly, operate all the buttons on the remote - again to un-stick any button. Return the batteries to the remote when done. If your remote has a lamp to indicate when a button is pressed, check to see if it is on with fresh batteries. Old batteries may not show the lamp being on, but still allow the remote to send a signal.
Jan 09, 2012 | Sharp LC52D85U 52 in. LCD TV
Ilo HD TV won't turn on
try another power cable (usually these tvs use the same power cords as a number of other electronics, such as desktop computers, etc) - if that doesn't work, try another power outlet - Also, try powering the tv on with the power cord out - this clears the static electricity off the system board, and helps w/ power issues sometimes - if still no power, then you can contact Wal Mart's customer service (since iLo is their in-house brand) @ 1-800-925-6278 to see if it's still under warranty or if they can put you in touch w/ an onsite technician.
Good luck - hope this helps!
Sep 13, 2009 | iLO V27DMBX Television
No response to any button on remote or tv except power button
Press the 'Favorite' button on the remote. You may have accidentally pressed it. It locks the channel. Pressing again unlocks.
Apr 22, 2009 | iLO 3200 32 in. LCD Television
ILO-2600 tv need power cord
If you use a standard power cord for most radio's all I had to do was round of the edge and turn it into a figure 8 , works good or the plug fron norelco or remington razors work too
Apr 09, 2009 | iLO 2600 Television
Need power cord and remote
Try Partstore.com. They have lots of replacements parts for TVs. good luck.
Jan 24, 2009 | iLO 2600 Television
Ilo power cord
Most computer power cords are the same as plasma power cords. Sylvania is made by Funai and that mnfg can be contacted for your nearest Funai rep. that supplies parts.
Feb 05, 2008 | Televison & Video
Ilo hd tv
Hey try unplugging your television and taking the batteries out of the remote control.. Wait about 5 minutes and try it then! Did that help? If not, your remote control code be broken or it could be your television, but most likely the remote, so I would recommend purchasing a new replacement remote control from a site like http://www.remotecontrolscenter.com instead of buying a universal remote control that you'll have to spend hours trying to program to work with your tv, instead the replacement remote will be an exact replacement for that broken remote control. Hope that helps!
Sep 06, 2007 | iLO V27DMBX Television
My manual tv controls don't work on the tv or cablr remote
Had the same issue 4 1/2 months after purchase(2 weeks after Wal Mart's warranty expired of course). I contacted Ilo and was told it was the main circuit board.
Aug 11, 2007 | iLO 3200 32 in. LCD Television
Ilo power cord
You may want to contact Funai. They are the company that makes the Ilo brand. Their parts department may be able to find the cable you need and order it for you. 800-242-7158 parts@funaicorp.com
May 09, 2007 | iLO 2600 Television
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
iLO 3200 32 in. LCD Television Logo
313 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
