Question about Whirlpool Refrigerators
Ref not cooling
Whirlpool ref et19rkx gwo2 03/99 top freezer freezer temp 15d box 54d help carolrossfish@bellsouth.net
    President:
  • 2,468 Answers
Remove the access panel in the freezer section and see if the evaporator coil is iced over,a little frost is o.k.,but when they are covered with ice they can't pass cold air,if this is the case defrost the coil with a handheld hair dryer,then check the defrost heater under the coil for continuity,if its good then suspect a defective defrost control be it timer or adaptive defrost
Posted on Jul 10, 2010
16cuft top freezer and bottom refrigerator. Condenser is in the back. Both ref. and freezer are freezing. how to fix it? 2nd whirlpool refrigerator 16cuft freezer is fine but ref. is not cold?
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 15, 2011 | Whirlpool ET1MHKXM Top Freezer...
I have the Gladiator garage frig/freezer. It either freezer both top and bottom...or it's off. We can't get the freezer to freeze at the same time that the refrigerator simply cools. We have not...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If
you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 08, 2011 | Whirlpool Gladiator Refrigerator
I have a whirlpool arc4170 fridge/freezer. The fridge is not cool and the top of the freezer is not cool but the bottom seems ok. Any idea as to what is wrong?
NOTE: This
If
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 04, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water in bottom of ref.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 06, 2011 | Whirlpool ET1MHKXM Top Freezer...
I have a KitchenAid refr. mod. KSRL25FRSS00 it is turned down to the lowest setting and still freezes things in vegetable box. (new control board?)
Is your milk or eggs freezing? All the cooling in the refrig and freezer spaces is done in the freezer. Sometimes, the control labeled freezer temp controls a vent between the freezer and ref space, allowing air into the ref side. the other control determines run time. try turning thefrz setting up to raise the ref temp.
Nov 15, 2010 | KitchenAid Refrigerators
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Placing a refrigerator in the garage
IF YOUR GARAGE TEMP GOES BELOW 35 THE REF MAY NOT WORK WELL BECAUSE MOST REF HAVE THE THERMOSTAT AS THE REF CONTROL. THE TEMP IN THE BOX IS SENSED AT THAT POINT AND SHUTS OFF, THE REF SEEM TO WORK BUT THE FREEZER WILL WARM UP.
IF YOU WANT TO USE A REF IN THE GARAGE, FIND ONE THAT HAS THE THERMOSTAT CONTROL AS THE FREZER CONTROL. LOOK AT THE CONTROLS, THE ONE THAT HAS AN OFF POSITION IS THE CONTROL THAT IS THE THERMOSTAT. SO, THE FREZER CONTROL SHOULD SAY "OFF" SOME NEWER REF WITH FULL ELECTROINIC CONTROLS MAY WORK AS THEY HAVE INDIVIDUAL SENSORS FOR BOTH THE REF AND FREEZER SECTIONS.
Jul 14, 2008 | Whirlpool EL7ATRR Refrigerator
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
