Question about HP OfficeJet 6210 All-In-One InkJet Printer
The paper is jammed. How do i get it out? - HP OfficeJet 6210 All-In-One InkJet Printer
    Genius:
  • HP Master
  • 1,354 Answers
Hi
1. 1
Switch off the printer and disconnect the power supply. Allow any residual charge to fade away before putting your hands or metal tools inside the chassis.
2. Step 2
Pin down the exact location of the jam. The three hot spots for a jam are the paper tray, anywhere between the feed tray and the print carriage, or between the print carriage and the output tray.
3. Step 3
Take off the front paper tray if the sheet got stuck while it was still in the front area of the printer. If the sheet jammed here, you should be able to see most of the paper.
4. Step 4
Pull on the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a chunk of it deeper in the machine.
5. Step 5
Open the back panel to reach paper jammed between the feed tray area and the print carriage of the all-in-one printer. Carefully remove the jammed paper from the machine.
6. Step 6
Use the carriage access door to reach a jam further inside the all-in-one printer. You may need to move the print carriage out of your way to clear the jam.
7. Step 7
Return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jul 10, 2010
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Oct 20, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
