Question about Fuji Finepix J20 Digital Camera
When I turn the camera on the lens extends but
I have a Fujifilm FinePix J20 digital camera. When I turn the camera on the lens extends but there is a soft clicking sound that sounds like a timer then it beeps and comes up with a "zoom error" and a red flashing light (not on the screen) appears . I can zoom the camera out but after that the camera is completely frozen and I can't do anything with it but shut if off. Any ideas what this error is and how I can solve it?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 10, 2010
Lens does extend but won't stay out long eugh to take photo
From your description, this could be a symptom of a failing or low-charge battery. Have you tried an alternative battery, or powering from the mains if this is possible ?
May 08, 2016 | Fuji Finepix J20 Digital Camera
Why won't the lens stay extended?
hi,
may be dust gone in side, it will obstruct the lens's side sensors.
with an air blower some times will clear this, if not must open and clear the sensor grooves.
Lens barrel wont extend
You have a problem with your lens, maybe a decentered lens. Make sure there are no obstructions in the way of the lens. It may need to be serviced.
Mar 31, 2014 | FUJIFILM Finepix S1500fd Digital Camera
I dropped my fujifilm finepix av100, the lens is now stuck and will not go back in when i turn off my camera. when i turn on my camera it says ''turn camera on and off'' but it doesnt solve the proble
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
Nov 17, 2011 | FUJIFILM FinePix AV100 Digital Camera
Finepix gives message to turn off then on again. keeps foping it no matter what.
It may be your lens cap. If the lens cap is on, the lens cannot extend, so the camera will give you notice to turn the camera on and then off again (assuming you know that you must remove the lens cap before turning on again. If your lens cap is off, check to see if there is anything else blocking the lens or impeding it from extending.
Aug 27, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
When turn camera on get message turn camera off then turn camera on again. did that and repeatedly get same message.
Check to see if your lens cap is on. If the cap is on, the lens cannot extend and you will get that message. If your lens cap is off, check to see if there is something impeding the lens and keeping it from extending. Your camera may "think" the lens cap needs to be removed.
Jul 28, 2011 | FUJIFILM FinePix S4000 / S4050 Digital...
Why can't I email my pictures? I have a camera (Fujifilm finepix J20) and while trying to mail my pictures through their email menu, a box came up simply saying it could not send the email. Any ideas of...
Right-click on a picture file, choose e-mail and you will have a choice of sizes. Pick one and your e-mail will open with the picture attached. Your original will be untouched.
Jun 16, 2010 | Fuji Finepix J20 Digital Camera
Fujifilm A345 camera
does this carmea have a zoom on it]
Jan 19, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji Finepix J20 Digital Camera Logo
385 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
