Question about Garden
I have a craftsman 2200 psi 6.75 hp Pressure washer. Model#580762202/Serial# 5003874. I had it sitting for about a year. When I tried to start it nothing happens. But when I spray gas in the carb and pull it it will start up then shut off. I took the carb off and cleaned the entire thing and yet continues to do the same. It will Stay running if i constantly spray gas in the carb. What could cause this??
  • 6,674 Answers
Did you check fuel tank and feed line to carburetor for dirt/obstructions?
Screen inside tank at fuel line connection may be plugged. Pull feed line off at carburetor and see what kind of flow your getting from the tank. I will assume you checked fuel inlet port of carb when you had it off to clean.
Posted on Jul 10, 2010
Where do i get a 2200 psi pump?
It depends on what you want the pump for, but at 2200 psi, I presume you are looking for something like a pressure washer pump.
Harbor Freight sells a 1600 or 2500 psi pressure washer
http://www.harborfreight.com/2500-psi-3-gpm-65-hp-212cc-pressure-washer-69734.html
If you need just the pump, here are a couple of websites to check out:
Pressure Washer Direct
http://www.pressurewashersdirect.com/power/pressure-washer-pumps.html
Northern Tool
http://www.northerntool.com/shop/tools/category_pressure-washer-accessories+pressure-washer-pumps?utm_source=Natural&utm_medium=Covario&utm_campaign=Pressure
And you can check on Amazon or eBay and see if someone is selling one there.
Sep 04, 2014 | Garden
What is the price and types of the pressure washers and where can i buy it?
Hi mary
About the price i think Mr JERRY is true
About the types there are many types like : -
- 2000 PSI Electric
- Gentron 2200 PSI Gas Pressure Washer
- Gentron 3000 PSI Gas Pressure Washer
- Gentron 4200 PSI
- 1600 PSI Electric Pressure Washer
- 2000 PSI Electric Pressure Washer
- 2200 PSI Gas Pressure Washer
And about the place you can buy these products, you can find many depots online like : -
http://www.generatordepot.us/pressure-washers.aspx
Thanks
Oct 30, 2011 | Garden
Craftsman Pressure washer will not spray
your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Sep 24, 2009 | Briggs & Stratton Pressure Washer...
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Jul 09, 2009 | Garden
Craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Jan 10, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
132 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
