Question about Maytag Neptune MDE5500AY Electric Dryer
My kenmore dryer is making a noise like the fan hitting something as its turning, other than that the dryer works fine.
    President:
  • 1,554 Answers
The blower may have a broken part and make the noise. Check the blower wheel and replace it if sign of damage is obvious to prevent further damage to other parts of the dryer. The blower wheel is accessible through the front or the rear of the dryer depending on the model. The blower wheel is located on the bottom left front of the dryer if it has a toe panel, otherwise it is located on the rear of the dryer.
Remove the toe panel or the rear access panel then remove the blower wheel cover. Please indicate the exact model number of the dryer for specific troubleshooting and repair advice. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 10, 2010
2 Suggested Answers
pgh_pa_guy
  • 2992 Answers
SOURCE: Kenmore gas dryer 97273100 was drying, but making a loud noise
You need a belt. Here's a link to a site with a good set of instructions if you want to try repairing it yourself. (You should DIY. You can save a bunch on the service call and the belt is only about $20.)
http://repair2000.com/wpoolbelt.htm
Posted on Dec 08, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Our Kenmore He4 dryer makes a loud noise somewhere between the sound of grinding the gears of a standard shift car and the noise that air wrenches make when the the lug nuts are fully tightened when...
Sounds like something is stuck in the fan. There is a squirrel cage fan that draws air through the drum. Take the front panel off and you should be able to see the fan. Or look in the lint trap slot with a light and see if you can see anything. I have also see the fans fail and come loose from the shaft.
Aug 07, 2013 | Kenmore Elite HE4 Electric Dryer
The dryer is making a thump/thud noise as the drum turns. The dryer works fine but the noise sounds like something hitting everytime the drum goes around. Could this be the belt going out?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Jan 02, 2011 | Kenmore 83142 Electric Dryer
Kenmore 11066812694 dryer whirring noise in back
Could be the rollers holding up the drum, or the motor blower fan.
Jan 18, 2010 | Washing Machines
Groaning Kenmore 13.5 cu. ft. Upright Freezer
This sounds like you either have a bad fan motor or if you have ice built up on the inside back panel. It could be that the fan blades are hitting ice built up around it. If so, you will have a defrost problem that will need to be addressed to fix the unit. But to repair it so it will stop making the noise, you can defrost the ice (if present) with a hair blow dryer. This will keep the ice away for a few days. Good luck.
If there is a defrost problem, the heater (located around the coil) is most likely the problem.
Nov 17, 2009 | Kenmore Freezers
My dryer is acting weird
your dryer motor is no longer strong enough to turn the drum,how old is the dryer?mike
Apr 04, 2009 | Kenmore Dryers
Kenmore dryer makes roaring oise when the drum turns
I have the same problem. I thought originally it was the seal around the drum but we pinpointed it to the fan motor. We think there is something wrapped around the fan motor or the bearings is going out.We would have to take everything out the drum and belt and motor to get to the problem. If you take the back panel off and take the lint trap off you can turn the fan and you can hear the loud noise. We tried spraying wd-40 around the fan pin but don't get any on the motor. It will burn it up if you do that. But it didn't work so you will have to take everything out.
Feb 01, 2009 | Kenmore 62602 Electric Dryer
Dec 08, 2008 | Kenmore 72982 Gas Dryer
Kenmore dryer model #11060932990
HAVE YOU CHECKED THE IDER ARM UNDER THE BOTTOM FRONT OF THE DRUM??????THANKS
Jul 23, 2008 | Dryers
Kenmore Ultra Care Electric Dryer
You have to go in the back.. take loose the blower cover and pencil is probly in parts after hitting blower fan.. check fan for broken blades ect.
Sep 17, 2007 | Kenmore 659 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
22 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
