Centeral air conditioner
Why would lots of moisture be dripping from the bottom of the furnace duct and the duct work inside of the house? Is there a water over flow somewhere?
  • 6,674 Answers
If cool air is moving through the duct work,(feels cool or cold) and the area outside the duct work is warmer/hot, then you will get condensation forming on the duct work. Wrapping the duct work with insulation should lessen, or eliminate that.
Posted on Jul 10, 2010
Air con has water dripping out the front
Does the fan work to evaporate the moisture? ACs are pretty easy to diagbose. Is it dripping in the house?
Mar 26, 2016 | Heating & Cooling
How do i change a filter on my amana gas furnace
the filter should be somewhere either on the end of the furnace or on the duct work itself.....this is assumeing you do not have a filter grill inside the house
Mar 19, 2013 | Heating & Cooling
Eddfx24fa2 model # on furnace of central air unit in my basement I am trying to calculate wattage of this central air unit On compressor outside: 220 volts, 60 amps??? Does amps sound correct? amps x...
It is a two ton system. and without doing a heat load Calculation and not knowing the heat load It would not be anything but a guess. But if everything is working properly and the system is clean and with good duct work, than it should be big enough for the size of your house.
Jun 06, 2011 | Airtemp B6Y12F2A Air Conditioner
I have 2 of the MSZ-A09NA Mr. Slim model in my 400 sq. ft. cottage. In the summer time my cottage is always damp feeling and the ducts drip condensation. How do I prevent this dripping?
It sounds like you have too much air conditioner vs. conditioned space. This would cause dripping and short run times. Air conditioners are designed not only to cool the house but to pull the moisture out, if it is too big and cools the area too fast the outside of the ducts will begin to collect condensation like the outside of a cold glass of water.
May 04, 2011 | Mitsubishi MS09TW Air Conditioner
My furnace isn't heating my house. I was wondering if this was because there is a vent from my cold air duct to the outside thus drawing to much cold air into the system. Should this vent be closed in...
If this vent is connected to the return air duct line back to your furnace I would close it off. The only reason that I can see for having a vent to the outside is if you need more combustion air supply.Thank you.
Feb 21, 2011 | Heating & Cooling
What is the purpose of the sailswitch
The sail switch is in the cold air return it is wired in with the humidastat when your furnace goes on the air movement pushs the sail down inside the duct work that makes a contact the lets the 24volts to the humidastat. If the humidastat calls for moisture it turns on the humidifier but only when the blower on the furnace is on So in short it detects air movement
Oct 03, 2010 | Honeywell HE360A1027 Whole House...
Is it normal for a car to drip water on the ground after running the air conditioner?
Yes, The air conditioner evaporator core inside the vehicle is very cold when the a/c is operating and moisture will condense on the outside of it, especially on a humid day. This moisture then trickles down the sides of the core and collects in the plastic housing beneath the core where it then escapes through the evaporator housing drain tube and drips on the ground beneath the passenger side of the chassis. The more humidity in the air the more moisture you will see dripping onto the ground. If the little drip hose should ever get plugged up this water then will overflow the housing and drip on the passenger side carpet so if you ever have that problem you'll know what the cause is.
Jun 17, 2010 | 2006 Chevrolet Trailblazer
Should I have a return air grill with a filter?
if the closet the inside unit is in is vented to the house the filter should be inside the unit at the top or bottom.
Phil
Jun 09, 2009 | Heating & Cooling
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
