Question about Whirlpool Refrigerators
Upper freezer is 15d. and box is 60d. help! - Whirlpool Refrigerators
  • 677 Answers
Any time the compressor is running the fan in the freezer should be running now you need to empty the freezer do you see a lot of frost on the back wall of the freezer you either have a defrost problem and frost has built up so much its stalling the fan or the fan its self is bad pull the back cover off the freezer wall and tell me what you see please also give me your model number off the serial plate which should be in the fridge section put your freezer stuff in the fridge while we check it out
pull the cover off the fan cover in the center of the freezer and see if the fan is plugged up then spin the blade with your finger see if it starts or some thing is jamming it.
ok you can take the top door off then remove the hinge pin in the middle and remove the lower door get some stainless steel washers that fit the lower hinge pin and start shimming the door up till the gap is filled put Vaseline on the washers and the top and bottom of the door bushings now after you put the bottom door back on put some kind of block to act as a spacer on the fridge door at the part where the handle is about 1-1/2 thick then put the freezer door on and tighten the upper hinge and remove the spacer also spray the evaporator fan with wd 40 dont forget my rating it helps with the site.
Posted on Jul 10, 2010
I keep hearing hat on a dualelement water heater that the lower element should be set about 15d cooler than the upper.
probably not right as there is only one thermostat control normally
duel elements are used to heat the water faster for recovery as the same size element in single use would be too big to fit in the unit
Apr 18, 2018 | Water Water Heaters
Where can I find a manual for wildgame innovations model 15D
Try Googling (wildgame innovations)(15D)(manual) without parens.
Oct 12, 2017 | Wildgame Innovations Cameras
Canon 60d internal flash not popping up
Check the metal tabs inside the notable rails as they need to touch the upper part of the rails to allow built in flash to work
Use a micro screwdriver to push the tabs up to the rail
GENTLY as that was what was wrong with my canon digital body
Jun 21, 2015 | Canon EOS 60D Digital Camera with 18135mm...
Lenovo Flex 15d windows 8.1 touchscreen unresponsive
Hello
Either you have turn the Touch function off or the problem might be with the connection its might be loose. You can check in the control panel for Touch function. Or your keyboard might have quick function keys. The bottom of the keyboard has (fn) and another key on the keyboard will have the touchscreen icon.
Apr 10, 2014 | Lenovo Flex 15D 2-in-1 15.6" Touch-Screen...
Touchscreen is not working
And suddenly, what did you add, remove, change OS, bend, break...
Freezer fine but fridge warm
The fan seems to be out looks like you need a new fan motor for freezer component
Nov 14, 2013 | GE PDS22SIS Bottom Freezer Refrigerator
I bought my new canon eos 60D..i put on external flsah to use..then after i take off the external flash, my camera's built in flash cannot pop up to take flash even i had press the flash button. How?
Hi, What external flash did you use on your Canon 60D? The internal flash will not automatically pop up if in the "Creative Zone" it will pop up with the button in the creative zones (M, AV, TV and P) it will not pop up with the button if you are in the the full auto mode (that's the little green box mode) but, should pop up automatically if required. The flash should pop up automatically in the basic zone for Portrait, close up and night photography, the button won't activate (pop up) the flash. Also the internal flash will not pop up if there is an accessory in the hot shoe. Again what external flash was it you used and did it flash?
Jan 27, 2011 | Canon EOS 60D Digital Camera
An English copy of the Canon EOS 60D Manuel: I
You can download the manual and more from
http://www.usa.canon.com/cusa/support/consumer/eos_slr_camera_systems/eos_digital_slr_cameras/eos_60d#BrochuresAndManuals
Oct 11, 2010 | Canon EOS 60D Digital Camera with 18135mm...
Ref not cooling
remove the access panel in the freezer section and see if the evaporator coil is iced over,a little frost is o.k.,but when they are covered with ice they can't pass cold air,if this is the case defrost the coil with a handheld hair dryer,then check the defrost heater under the coil for continuity,if its good then suspect a defective defrost control be it timer or adaptive defrost
Jul 10, 2010 | Whirlpool Refrigerators
Frost in freezer
sears parts direct can send you a new door gasket. they dont need the size only the model #. p.s make sure gasket is soaked in warm water before you install it .this make it easier to work with.
Feb 24, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
13 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
