Question about Brother LS-1520 Mechanical Sewing Machine
Bobbin thread problem
When i try to sew the thread in bobbin area gets all tangled up and thread gets wrapped around hook and hook center post. i need to fix fast. have to finish quilts for charity auction in 24 hours.
  • pumbaapower Jun 08, 2008
    I have trouble with my machine bunching the thread on the bottom side of whatever I am sewing. Eventually it gets too tangled and the machine gets stuck. How do I fix this?
How do you re time a machine
Posted on Jun 27, 2008
Thread gets tangled underneath
around the post? is the bobbin and bobbin case in the machine?
Feb 18, 2014 | Janome Sewing Machines
When winding the bobbin, the thread keeps wrapping around the bottom of the bobbin post
Make sure the bobbin is pushed all the way onto the post and that the thread is running through the tensioner on top of the machine above the needle area.
Jan 16, 2010 | Bernina Sewing Machines
Thread gets tangled in the lower bobbin area
Make sure you insert the bobbin into the bobbin case correctly. In the bobbin case there's always something that you have to hook around.
Dec 18, 2009 | Kenmore Sewing Machines
Hand wheel is hard to turn
If you take out the bobbin case and slide off the needle pate, you can inspect the bottom area for a thread jam. The black post that the bobbin case slides onto is called the thread hook. It should have a loose feel to it when you gently move it around, it should not have a "solid feel".
Another area that sometimes wraps the thread is the take up lever area.
(the lever that moves really fast up and down as the machine is sewing)
If the lever has been pushed to the left, it's possible the thread has wrapped up in that area.
If those two areas are o.k. you'll need to take it in for service.
Oct 16, 2009 | Husqvarna Viking 1
Burnette 65 bobbin tangling can't adjust thread tension
Have you replaced the needle with a new one? Your needle may be bent or in wrong, or the wrong size. You may have a bad needle. Check that the upper thread path is running freely and is not tangled or wrapped around anything. Make sure that the bobbin is unwinding in the correct direction as well, most bobbins, this is clockwise as the bobbin faces you. If you are using inexpensive thread, it could be the thread that is the culprit. Uneven thread in the needle will not flow through the needle properly, and cause bunching as well. Save it for the bobbin, and use good thread in the top.
Jul 16, 2009 | Bernina Bernette 75
Thread tangles under throat plate while embroidering
Could the little hook that is stuck over the bobbin area be the thread cutter? My thread cutter gets stuck there and I have to turn my machine off and then try to use the cutter to reset it to its "resting" position.
Nov 23, 2008 | Brother SE-270D Computerized Sewing...
Bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
Jan 30, 2008 | Brother XR-65t Mechanical Sewing Machine
Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at for more information.
Oct 27, 2007 | Sewing Machines
Brother LS-1520 Mechanical Sewing Machine Logo
192 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
