Have a reel to reel tape recorder that has a bad Hum in playback mode. What could cause that?
  • Robert Hunt Jun 12, 2012
    Can you hear the hum in both channels? If not, then the problem could be somewhere else.
  • Audio Player... Master
  • 5,487 Answers
Most hum is caused by a faulty electrolytic capacitors. If the hum is accross both channels, then it's most likely one in the power supply part. Maybe the big one that filters the 50/60hz mains hum. The reason you will hear it in playback, is that a switch will be opened up when the mechanism goes into play. This switch connects the tapes pre-amp to the audio out circuit.
Posted on Jul 14, 2010
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
AKAI X-1810D LOW HUM WHEN RECORDING REELS
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Sep 05, 2012 | Audio Players & Recorders
How to get rid of hum in output of my Akai 4000ds Mark II reel to reel tape recorder
I can't see this question answered anywhere. There is information for fixing hums on bother the Mk I and Mk II models of the Akai 4000DS here:
http://electronicaid.webs.com/
Oct 25, 2011 | Quantegy 456 Reel-To-Reel Recording Tape
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
The unit is eating up the tape!
Generally speaking, there are two reasons this happens.
[1] tape recorders have to move tape past the record/playback heads at a highly consistent and accurate rate of speed. What makes this possible is a rubber "pinch" or pressure roller and a spinning metal spindle. Tape is routed between the roller and the spindle, and when the recorder is in RECORD or PLAY mode, the roller presses the tape against the spinning spindle, causing the tape to move from the feed reel to the takeup reel. When the pinch roller and/or the spindle become coated with oxide particles shed from old tapes, they get sticky and the thin tape will begin wrapping around one or the other. THE SOLUTION is to get some cotton swabs and rubbing alcohol and clean the oxide (brown from cheap tapes and dark gray from better tapes) from both of these parts.
[2] many tape recorders use rubber belts and pulleys to turn the feed reel and the takeup reel. If the tiny rubber belt that makes the take-up reel turn is stretched, it will not wind moving tape fast enough, which causes tape to bunch up. If this is the problem (you will not be able to see the belts without removing the recorder's outer case), then you might as well junk the recorder.
If you see that the part of the rubber drive roller that contacts the moving tape has a ring of brown or gray coating on it, you
Feb 19, 2010 | Sony TCS-580V Handheld Cassette Voice...
Sony TC-530 hum in internal amplifier left channel.
Electrolytic capacitors are good at causing hum. You could try replacing some of them, they are not expensive. Otherwise you might have damaged the left channel amp semiconducter, whatever that might be.
Nov 25, 2009 | Audio Players & Recorders
My AKAI GX 636 records but can't hear anything on playback (had recorded tape play on another reel to reel) plus the VU needles don't move when you try to play a recorded or pre-recorded tape
Trace the wires from the head to the amp section. Put your finger on where they join (during playback) and see if you can get a buzz. If you can't on either channel, look for something that might be common to both channels. Either a switch, or a pre-amp IC, as being the cause of the fault.
Jul 18, 2009 | Audio Players & Recorders
Reel to reel tape recorder hum
Try replacing the Electrolytic Capacitor(s) on the power supply. They will be big value anywhere between 2,000UF and 6800UF. But capacitors of this type are notorious for causing hum, any on the deck could do it!
Apr 05, 2009 | Audio Players & Recorders
Hum from vintage Akai DV-4000 open reel tape deck
I have an Akai 4000ds Mkii which had quiet but noticeable hum. I managed to fix it entirely but I had to remount the transformer in a different position and orientation, presumably to 'balance' the magnetic induction it caused in the chassis. I further reduced the hum by adding some steel sheet to the chassis. All this has to be done by trial and error using scrap steel so you need to be exceptionally careful about where the various mains tags are located. You may not be prepared to move so far away from the original design but I suspect your hum is caused by mains induction from the transformer shooting around the chassis. If these currents pass through the chassis anywhere near the playback heads, you are likely to get significant hum.
Mar 26, 2009 | Audio Players & Recorders
197 people viewed this question
 Grubhead
Grubhead
